I am a expert with onther machines but not dyson cr01 it making like a clicking noice like a relay on pcb and the front panenel is flashing whats the problem please any light is better than none
Hi Kenneth, it's Jack at Dyson.
Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 we proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
If you would like to discuss your concerns further with one of our experts, you can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
Alternatively you may wish to check with local repair services for advice - please note, we cannot recommend or endorse specific repair companies.
SOURCE: F14 error code, and says Flooding. Help please.
F/14 ERROR CAUSES DUE TO:--EEPROM ErrorThe Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU. If there is an error reading this data, it will cuse this error.
TO RESLVE THIS ERROR MANUALLY TRY THIS BEFORE CALLING ENGINEER :--
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
SOURCE: Dyson CR01 front panel removal help
Remove lid, two screws at rear, slide back and lift. Remove control panel, two screws at top, lift and remove ribbon cable. Outer door, open and remove screws from hinge. Front panel, remove two top screws. Front panel lifts up and inch and pulls foward. You might need to move penny trap. To do this, remove rear panel. Right lower hand side, remove motor and mainboard to facilitate space for and arm, have fun! Penny trap and pump are not screwed down. They are hooked over the front metal plate, just lift and pull backwards! I had to remove everything from the machine just to get at the penny trap!
SOURCE: This morning got F11 fault on Dyson CR01 front
may be the rear bearing has gone,my con/rota packed in and i took the drum out cleaned ,replaced, greesed, and alls well , if it is the rear bearing DON"T let them tell you its scrap if you are good at diy you can take the bearing out and fit new one, bit of a time comsumeing job
i have checked the bearings and they are ok it making a clicking when you first switch on with front panel flashing i thought was door catch energising but not checked top panel no relays on thers any help please its a cr01
