Question about AEG Freezers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
SOURCE: Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
Posted on Jun 12, 2009
SOURCE: Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Posted on Jul 02, 2009
SOURCE: My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Posted on Jun 14, 2010
SOURCE: FREEZER ALARM WILL NOT SHUT OFF
I have a Kenmore upright freezer Model 253-9266412
the alarm will not go off
Posted on Jun 27, 2011
Jan 26, 2016 | Freezers
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Feb 05, 2010 | Freezers
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Mar 11, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Feb 09, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Apr 01, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
82 people viewed this question
