Question about Zenith Z27X22D 27" TV
I wish to find a manual service for a Zenith TV, model Z27X22D (serial number 721-45401864).If it is not available, can you tell me what I would need to set this TV up to receive Internet streaming vi
See above.
Posted by geodesic842 on
3 Related Answers
Anonymous
  • 1284 Answers
SOURCE: Need service menu access instructions.
Done!
Posted on Feb 07, 2007
Anonymous
  • 556 Answers
SOURCE: TV Problem
picture is milky white is due to crt.if it is old set. or check video section
Posted on Sep 21, 2007
Anonymous
  • 556 Answers
SOURCE: Zenith Z27X22D Service Menu Codes needed
significant vertical overscan. It is such that it's impossible to read crawls and such at the bottom of the screen. I think this problem is a tv problem. it is due to vertical section. please change electrolytic capacitor in vertical output section. it will be ok. it is common problem can be fixed at home & very simple.
Posted on Oct 06, 2007
How can i find out more information about older zenith t.v. ?
IF you have the serial number you should find the model number.
The model number is essential for getting more information. One trick is to put 'old Zenith TV images' in Google. You will get lots of pictures. Find the pictures of yours and some will have the model number stated. From there you can do search on that model number. You should be able to locate manuals, etc.
4answers
Need a copy of TV Manual for an old TV, 1998 Zeneth 13" Color TV, Model AS 1340, Serial Number V15800940
HI,
The manual for your model is not available.You will have to contact zeneth for it.
Schematic diagram serviceinfo
Schematic diagrams are in PDF, and cannot insert by this window. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Hello, I have a Zenith Concierge model number
Codes to check with Zenith brand TVs are: 0287,0281,0288,0285. Try these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy In case of service manual, I've it with me, but cannot upload it by this window as it is in PDF.
In case of service manual, I've it with my system library, but cannot upload here by this window, as it is in PDF.
google.com/+GopakumarGopalan
Service menu instructions needed
service menu code is 9876, i think. and you can manually adjust the focus using network54's post on "blurry z27x22d".
2answers
Picture is dark
Does not seem like a bad tube alone. Could also be that the Video output Transistors Supply Filter capacitor having dried out. It is a 100mfd 160V capacitor, which on replacement will improve the brightness of the immage. And yes, you could also try increasing the heater voltage (Filament Voltage)of the Pictuire tube, this will definitely increase brightness, but will reduce the life of the Picture tube. You gotta think - 10 year old TV, should I repair or exchange and get a new one???
Televison & Video Logo
Top Zenith Televison & Video Experts
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
