Replaced screen and motherboard and still same problem except now there is NO image
Did you also replace the inverter??long ish piece of board two long wires attached.this is used to light the bulb on the screen,also if you turn the pc to a light when switched on can you see any image will be faint???if you can it will be the inverter..also the screen you put in are you sure the light works. hope this helps
If the laptop has no image at all it can be video card or LCD cable or the LCD panel. About the only non-invasive test you can try is to plug an external monitor into the laptop. This will determine if the problem is motherboard/graphics card or lcd cable/lcd screen. If you have an image on the external monitor then its likely to be lcd/cable/lcd screen.
Is the Displayed Image Faint?
A dim screen can be caused by three things;
1/ The LCD inverter which runs the LCD backlighting
2/ The CCFL backlighting fluro tube in the LCD panel
3/ The motherboard supplying signal & voltage to the inverter.
Thanks
