Question about SMC EZ Connect g SMC2862W-G 802.11g/b Wireless Adapter
Smc networks driver ez connect tm g 802.11g wireless USB 2.0 Adapter
1 Related Answer
Anonymous
SOURCE: SMC EZ Connect(tm) g 802.11g Wireless USB Adapter doesn't work
Try this site
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_USA&knowsPartNumber=false&productCategory=5&modelNumber=585&partNumber=3203&downloadType=0&os=0
If that doesn't work go to SMC.com click the support tab and follow the instructions.
Posted on May 01, 2009
When I plug in my ez connect adapter to the USB port the computer re boots over and over
Damaged usb port? See if contacts are bent. Bad wifi adapter is possible. Try another wireless device in the port (mouse, keybd) to see if port is okay. Some adapters require that you install software before using, but this should not cause reboots.
Feb 05, 2014 | SMC EZ Connect g SMC2862W-G 802.11g/b...
While installing kies set up on my window pc 1670 unable to load module error code5
Kies is software to access your Samsung device... why does this question reference an SMC USB 11g WiFi adapter?
Nov 18, 2013 | SMC EZ Connect g SMCWUSB-G (SMCWUSBG)...
I don't have the installation disc for the SMC EZ Connect g SMCWUSB-G 802.11g Wireless Adapter. Is there any website that I may get it from?
Try this site to get the drivers for the SMCWUSB-G: http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_USA&productCategory=5&modelNumber=1545&partNumber=0&downloadType=1&knowsPartNumber=false . You will need the part number of your adapter. Then choose your OS and click the blue button with the right arrow.
The manual and firmware are also available. See http://www.smc.com/index.cfm?event=viewProduct&cid=5&scid=31&localeCode=EN_USA&pid=1545 . The links for support and documentation are on the right hand side of the page.
I hope this helps.
Feb 22, 2013 | SMC EZ Connect g SMCWUSB-G (SMCWUSBG)...
I want SMC Networks SMC2862W-G EZ Connect g 802.11g Wireless USB 2.0 Adapter driver for Windows 7
http://download.cnet.com/smc2862w-g-ez-connect/3000-2112_4-64680.html
if this driver does not work
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope it helps
Jul 12, 2012 | SMC Networks SMC2862W-G EZ Connect g...
I have installed a SMC2862W-G wireless usb adapater on my pc. it is recognizing my wireless router and it is showing a decent signal strength in the SMC utility. However, my wireless connection icon on my...
You need to install the driver disk that came with the USB adapter. Your PC correctly pointed out that the internal WI-FI adapter is not working but the USB adapter should be showing on the taskbar of the driver is installed correctly.
Mar 08, 2018 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Vista Drivers ?
Have a look on this site
and download and install
if not workimg reinstall the app in compatibility mode in vista
http://download.cnet.com/SMC-EZ-Connect-Wireless-USB-Adapter-SMC2662W/3000-2112_4-67720.html
Feb 20, 2010 | SMC EZ Connect g SMCWUSBT-G (SMCWUSBTG)...
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
SMC EZ Connect g SMC2862W-G 802.11g/b Wireless Adapter Logo
347 people viewed this question
Top SMC Computers & Internet Experts
Jeffrey Groves
Jeffrey Groves
Gene
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
