I phone get warm and the battery will drain in 6 hours with out using it
The power cell should only get warm if you have it powered on all of the time. That is natural. 6 hours is short, and that may be one of two problems, the time of charge is too short, or the battery is dying. HINT! If you replace with a NEW battery; you must set the battery memory for the start. That means, when you first charge it, make certain it gets a long 24 hour charge to full. Use the phone until the device shuts down because the battery was exhausted. Now Do a full long term Charge. That process will set a Memory for the Power Cell and allow you to fully charge and discharge the battery from there on. One more thing...if you use a Charger Device, make certain it is working OK or else the Battery will not charge well.
