It was working with windows sp3. i tried to instal a new copy of windows7,During the instalation i did cancel. Ofter that, it doesn't get boot and bios again.If unplug hard disk then it will be ok, otherwise some instructions stay on the screen like this"ultra DMA mode,5-S.M.A.R.T capable status ok. it has 40 gb hard,1gb ram already.
You were running Windows XP SP3 and you want to upgrade to Windows 7. Windows 7 and Windows XP are technically very different and apparently your Amilo is not capable of running Windows 7. It requires more RAM, more disk space and also more powerful hardware. You should visit the Fujitsu website to find out if your computer can run Vista and Windows 7. Personally I doubt that.
SOURCE: Fujitsu Simens Audio Problem
i have the same problem too, i already installed my v3515 audio driver, but still doesn't work. i solved my problem the time that i change my Windows Xp installer. or from sp2 to sp3.. hope i help you....
SOURCE: How to Reset or Remove Acer Aspire 4752Z BIOS password?
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware.
I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
