Question about Microsoft Excel for PC
SOURCE: office 2007, home and student, constantly crashing
Theres a plugin that was recently added or modified that crashes your Microsoft Excel. If you still have the CD with you, I recommend that you UNINSTALL first the whole MS Office suit, restart, then REINSTALL the whole MS Office suit.
Posted on Jun 14, 2009
Testimonial: "till now it looks like your advice did help. Thanks"
SOURCE: same exact problem
What you need to do is to reinstall the Internet Explorer 7. Go to the control panel and click on add/remove programs. Look for Windows Internet explorer 7 and remove it. Download the Internet explorer 7 from www.microsoft.com and search for Internet explorer 7
Posted on Sep 10, 2009
SOURCE: Problem signature: Problem Event
Try this
When prompted, click "Remove driver and driver package."
Answer "Yes" when prompted to delete the driver.
4.You will then see a dialog indicating that driver package information has been collected. Click on the "Delete" button.
5. Back in the printer list, delete the offending printer by clicking on it and pressing the Delete key on your keyboard.
For really stubborn printers that refuse to delete, note the files the printer driver uses and delete them while in safe mode. To do so, on the "Drivers" tab (see above), click the printer and click properties. Sort the "File" column alphabetically by clicking on the heading. Write down the files involved and also write down the "driver path" above the "File" column. Delete these files in safe mode, then repeat the removal procedure above.
OR if problem is due to a corrupted spool queue
Open up c:\windows\system32\spool\PRINTERS
Delete the contents of the directory (not the directory itself).
Retart the print spool service
Posted on Feb 01, 2010
SOURCE: Close the Programe (Notice)
User permissions issue. Go to C:\program files\microsoft\fsx and find the fsx.exe icon. Right-click it, choose properties, and tick the check box for "always run as administrator". This process doesn't always work doing this from the FSX shortcut.
Posted on Jul 12, 2010
SOURCE: windows 7 problem
try to connect the usb HDD in windows with safe mode(by pressing F8 while booting ) and try to check the HDD system disk by windows tool, this might solve some errors. and restart ur device & can work normally then, if windows found errors on ur harddisk & fixed them. good luck
Posted on Jan 09, 2012
