For Atheros AR8121/AR8113/AR8114 PCIE Ethernet Controller v1.0.0.9 2008/04/25) Check Cable connection! PXE-MOF: Exiting Intel PXE ROM. No bootable device -- insert bot disk and press any key
hfc_32 - Hi, your system is telling you that it can't find a boot device (Your hard drive) and is trying to boot from a network instead (PXE) which doesn't exist.
Either something is wrong with your hard disk or somehow the boot device got changed in your system's BIOS.
You didn't say anything about your computer (laptop, desktop. Mac or PC?). There are a few things you should try (if you're comfortable doing it).
The easiest thing to try is to get the CD/DVD of your operating system and place it in the optical drive (with the error you described on the screen) power it down and then in turn it back on. It should boot from the OS disc and let you know if it finds your hard disk. You didn't specify your OS so we can't go any further there. Hopefully it will find your hard drive. Then you'll know that it didn't die.
If the disc doesn't see the hard drive and your PC is a desktop system (don't do any of this with a laptop) open the case and make sure the power and data cables are securely connected. Try booting again. The hard drive will be in a cage type holder usually at the front of the system.
Lastly, if the system still doesn't boot look in your system manual and find out how to get into the system BIOS. Follow the instructions and go to the Boot section and see if you hard disk is listed and if so make sure it is listed as the FIRST boot device.
To try to get into the BIOS if you don't have the manual try hitting (on separate boot attempts) at the beginning of the boot process (when you first see the white text on black boot screen just after you've applied power) first the key, then if that doesn't work, next try the key, then the key and finally try hitting the key.
Good Luck and Thank You for using 'Fix Ya'
Mikeywaf
