General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
Bleed valve on my gxwh40l GE house filter is leaking. Tried cleaning it, no change. What is the simplest fix without tearing the plumbing apart and replacing the entire unit ?
3 Related Answers
Anonymous
SOURCE: Slow water flow from GE SmartWater under sink water filter.
I solved the problem! The system's manifold (the plastic base you put the filter in) has small black conical shape button. When you tight the filter in, one of the two small triangle-shaped cams (located close to the filter's central hole) pushes the manifold's button, and this opens the water flow. The problem is that the cams are too low and do not push the button all the way in. Take a pliers and squeeze (not too much!) the cams, so they will raise a little: it will be enough to push the button to open the flow completely.
Posted on Mar 22, 2009
Anonymous
  • 1015 Answers
SOURCE: I just installed 2 new GE-GXWH40L filters
This is proabably not the case but I have seen it happen, Have you checked the outlet side of the filter to make sure it was drilled when it was made. Thank you
Posted on Nov 29, 2010
h2oservices
RJ H2O
  • 311 Answers
SOURCE: GE Heavy Duty Household Filtration System
It sounds like there is quite a bit of sediment in the water. The filter you are using may be a very fine micron 5-10. Try using a 30-50 micron filter.
RJ
Posted on May 17, 2011
5helpful
3answers
The red pressure relief button on my GE Smartwater whole house water filter system is leaking what do i do to stop this
I had the same problem. The valve is not seating properly. I first took a plastic bag and placed it over the unit so it didn't spray all over, then, pushed the button several times to try to flush it. I then shut the water supply off (or move lever to bypass) and removed the cannister that holds the filter. I activated the red button several times until it looked like it seated well. Keep as much water in the cannister(sump) as you can and still have the filter seated properly. Screw it back on, and open the water supply slowly to fill the rest of the way. Don't push the red button again, but instead open a faucet in your house for around 5 minutes to let air circulate out. If the red button still leaks, you may have to try a few times. If it leaks just a little it may stop after a day or so. Once you get the red button to stop leaking, don't push it again! Just always use the open faucet method to work the air out. There will still be some air bubbles for awhile, but will work out within a day
I installed the GXWH40L water filter. My repairman said now only hot water is coming out of my garden hoses. What happened?
Hi Installed incorectly...You have gravity by-passing (flow) into the cold water pipe.Maybe have a check valve installed to stop flow during stand-by time. thanks
Ge smartwater wholehouse waterfilter main housing failed flooded house
Why did it fail? How did it fail? Was it the plumbing that failed? Replace it with a Pentair filter housing, 10" housing, 20" housing or Big Blue housing and make sure it is plumbed in properly. It is very unusual for a filter housing to fail unless it freezes up.
RJ
We also installed the water filter GXWH40L. We never had any issues and have gone through probably five replacement filters. We recently changed the filter and have horrible water pressure. We changed it...
If you have GATE valves on either side of the filter make sure the have opened all the way. They can become unscrewed and although it seems like it opened they gate can be almost closed. If the outside spigots are on hard water try the pressure there.
Water filters for pre-filter housings come in different micron ratings. They can be anywhere from .5 micron on up to 100 micron. The smaller the number the finer particulates it filters out and the faster it will plug up. Generally most filters used for residential households are 5 micron to 50 micron rating and the most common used are 10,30 or 50 micron. Try a 30 or 50 micron filter to see if it helps. But remember the larger the micron rating the more particulates pass through.
If there is a lot of sediment coming the well and building up in the bottom of the pre-filtet housing you may want to flush the well or consider having the well inspected by a well company. You could have a pinhole in the drop pipe that is letting sand in.
Run one of the outside spigots in to a clean white bucket, let the pump cycle several times and inspect for sediment in bucket, let it settle for about 20 minutes to see if excess sediment is coming from well. Have your water tested to see if the water chemistry has changed also.
RJ
I just installed 2 new GE-GXWH40L filters installed on each side of my new GE water softner. I can not get water to go through the filter. Works fine in bypass. I triple checked the flow direction and it...
3helpful
I was changing my filter in the ge filtration system, and it says to turn off the water and press the red button. Then it says to unscrew the filter take the old one out and clean the filtrstion system...
The red button is a pressure relieve valve. If the system is leaking from the valve, try pushing the valve up from the underside of the cap where the valve is located. If this does not work the housing needs to be replaced. You do not have to replace this with a name brand like GE. All you need to do is make sure the housing that you are purchasing is the same size.
Example of Replacement Filter Housing: http://www.freshwatersystems.com/c-107-filter-housings.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Only hot water in sink/basin when toilet is flushed
I had a customer a few weeks ago that had the same problem. When the water heater was installed they crossed the supply lines. They had the inlet as the outlet. Esentially, the water heater was plumbed in backwards. Also there could be a miss piping somewhere in the house but it would probably be near impossible to find it right now without tearing up foundations. Also check that the faucet is not plumbed backwards as well. Especially if this is a single handle faucet that you are referring to.
Top General Electric Water Heaters Experts
RJ H2O
RJ H2O
Paul Carew
Marvin
Marvin
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
