Question about Audiophase MDP-1 Personal MiniDisc Player
Audiophase mp3 -how do i charge?
Nowhere in the instructions does it tell me how to recharge the lithium battery...help!
Just plug it into the usb port on your computer. you'll se the battery meter as it charges.
Posted on Oct 30, 2007
  • Anonymous Oct 30, 2007
    I screwed up! It has an a/c adapter to plug into the wall.
6ya staff
SOURCE:
On the back of the unit there is a small off on switch which just says charge? Not sure where that charge is coming from. Unit is not working at present.Item is Audiophase 315 cd player
The charge switch is used when your Audiophase CD player is using rechargeable batteries. The external plug-in power supply is used for charging.
Feb 06, 2017 | The Audio Players & Recorders
My nextar will not turn on and it is straight out of the packaging. When the usb is plugged in, the two default songs are listed, and they are able to be played. Please help me with this issue, as I...
I think you have a new device and you wanted to use it at first and the battery wasn't charged.
The player has a built-in lithium-icon rechargeable battery. It is charged via USB connection. You
are required to charge it when you use it for the first time. It takes about 3 hours to fully charge the
battery. Connect the larger end of the USB cable to the USB interface of PC, and connect the
other smaller end of the USB cable to the USB interface of this player. The device is connected to
PC and being charged.
For maximum performance, lithium-ion batteries need to be used often. If you don't use
the device often, be sure to recharge the battery at least once per month.
I hope your item will work fine after the battery is charged.
Thanks.
gylacz
May 03, 2011 | Nextar MA797 MP3 Player
When charged V2 does'nt hold charge for long.
Hi.
Most likely this kind of problems occurs when the battery is exhausted after a long time of using it.
because even intergrated (rechargeable) Batteries Wont Last forever. the chemical substances(lithium-ion) in it Drains after a period of charging/discharging(using the device).
Solution:
if you have a common Mp3 player, You can purchase a new fresh battery and replace it. its quick and easy.
i can instruct you if you want so.
First check ebay for the exact same battery that you have inside you Mp3 Player.
Learn More about Lithuim-Ion Batteries on HowStuffWorks.com
Good Luck
Thank You.
Nov 03, 2009 | Audio Players & Recorders
Explosion of a lithium ion battery
this is also called reverse charging.
Reverse charging, which damages batteries, is when a rechargeable battery is recharged with its polarity reversed. Reverse charging can occur under a number of circumstances, the two most important being:
  • When a battery is incorrectly inserted into a charger.
  • When multiple batteries are used in series in a device. When one battery completely discharges ahead of the rest, the other batteries in series may force the discharged battery to discharge to below zero voltage.
Apr 25, 2009 | Transcend T.sonic 320 MP3 Player
Replacing the rechargeable batteries
Radio sHACK OR bATTERY wORLD
Feb 06, 2008 | Baby Gear
Audiophase MP3 player charging
power u are getting to the mp3 player is only from the computer sounds like u need a new battery
Jan 14, 2008 | Audiophase MDP-1 Personal MiniDisc Player
Charging your Mp3
I am having the same prob. I bought two for my kids and they won't charge. Can anyone help?
Jan 05, 2008 | Audiophase MDP-1 Personal MiniDisc Player
Mp3 player
to turn it on you must turn it on and hit power if it wont work even on the cpu it's most likely broken and you should get it fixed
Dec 20, 2007 | Audiophase MDP-1 Personal MiniDisc Player
Contact you local Batteries Plus store. they seem to have just about everything! http://www.batteriesplus.com/
Sep 17, 2007 | Audiophase CDM450 Personal CD Player
Audiophase KZIII 1GB not being recognize or working
Ok for the KZ111 and KZ100 audiophase. turn the mp3 player on. then plug it into the computer. the player will start charging. Go to windows explorer or my computer and you will see it listed as a hard drive. Create a folder called music. you can then drag and drop mp3 files into the music folder. As for charging the battery my Motorola V170 cell phone has a usb charger. I use it to charge my mp3 player takes about 20 minutes. and the charger in my car for the phone works too. Hope this helps.
Sep 04, 2007 | Audiophase MDP-1 Personal MiniDisc Player
Audiophase MDP-1 Personal MiniDisc Player Logo
57 people viewed this question
Top Audiophase Audio Players & Recorders Experts
Ekse
Joaquim Martins
Are you an Audiophase Audio Player and Recorder Expert? Answer questions, earn points and help others
