Question about Gateway 2520915 Keyboard
Computer only buzzes doesnt get past start up page
Posted by James Farransr on
Grognard
    Novelist:
  • 126 Answers
Buzzing usually means one of two things: you have a bad CD/DVD in the CD/DVD drive (which would not usually interfere with booting up so that's probably not it in this case) or you have a bad hard disk. Try putting your Windows installation CD into the CD drive and booting from that. If the computer boots successfully, you have a bad hard disk. In that case, you will probably have to get a new drive and take the old one to a pro to recover any important data.
Posted on Dec 12, 2013
Drum doesnt turn dryer makes buzzing noise
Just fixed one with same problem for customer. Sorry to say but most likely faulty motor. One test you might perform, and this isn't full proof but, is to bypass door switch and attempt to turn drum by hand whilst engaging starter switch. If dryer starts it is most probably motor. Also If this usually occur after heavy usage, or has in the past, it's almost surely faulty motor.
Aug 20, 2013 • Dryers
1helpful
2answers
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
1helpful
I'm looking for instructions on a graco pack n play bassinet. Model No.# 9046XT.
Try this page at Gracobaby.com If it doesnt work try the second page and choose which playard
you think is closest to yours and download the instructions. You can save them on your computer
using the Adobe SAVE function. Just remember where in your computer, you saved it.
You will have to copy and paste the first URL as Fixya limits characters is a URL link or simply
use the second link and continue with CLASSIC PLAYARD
Graco Classic Playard Manuals
http://www.gracobaby.com/CustomerService/ProductInstructions/Pages/default.aspx?page=ProdInst
Mar 18, 2011 • Baby Gear
1helpful
Subwoofer is buzzing when volume turned up just past middle level-in other words it doesn't take much for the subwoofer to start buzzing
You may have overdriven the woofer at some stage, and torn the cone. Once that happens, the tear will start flapping (buzzing) whenever the volume is high enough to vibrate it loose.
If thqat's the case, you'll need to replace the woofer inside the cabinet - or replace the set of speakers, which is probably more economical for you.
MP4 MOBILE CINEMA HOW DO I LOAD MUSIC FROM MY PC
Depending on the type of file format that your player will play meaning mp3 wma etc. all you need todo is open the window or file with your music then in your computer start menu go to my computer and open with the player pluggedn into the computer double click the player icon if it doesnt open a blank window select the audio tab and drag your music over to that page each song or by complete file. to drag use your left button and hold down while dragging to the player page. or edit at top of music page then select all right click cut then onthe player page right click paste. these options should help you.
1helpful
Monitor Buzz on start -up
Try a different monitor or this monitor on a different computer. If it makes same noise on different machine or new monitor makes no noise on your machine you need a new one.
Doesnt switch on
You said buzzing sound is this more like a beep? Beeping sound are indicative of any number of diagnosable issues, depending on the actual number of beeps and the type of motherboard.
2answers
Dryer doesnt turn on
take the top of your dry off and look by the buzzes to see there fuse there it could need new one
2answers
Speakers Buzzing Whilst Playing Music
sounds like interferance try moving the speakers around maybe away from the monitor and try turning off any thing elec around your pc to find out maybe what is causing this
Gateway 2520915 Keyboard Logo
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Michael Thomas
Michael Thomas
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
