There are several wide streaks of color through the vertical center of a color image we try to scan. We use the i1420 and the companion A3 Flatbed. We have tested and had similar results with 2 different flatbeds and the i1420, so it's not a hardware issue. So maybe settings? We have tried virtually all related setting combos, options, etc. with no success. When we scanned some color documents recently, we used background fill and we did not see the streaks. When we scan in BW there is no streak. When we scan in greyscale, there are streaks of shading.
SOURCE: i620 scanner
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
