Question about Amana ABB2527DEW / ABB2527DEB / ABB2527DEQ Bottom Freezer Refrigerator
Remove door handle
Need to remove handle to reverse door on Stainless model
1 Related Answer
Anonymous
  • 104 Answers
SOURCE: I can't remove the door handle.
thanks
Posted on Feb 14, 2008
Whirlpool stainless french door refrig...need to take handle off bottom freezer door so I can move it out of house. Is this possible without taking off the whole door?
it is much better to remove the complete door instead of handle . there are 4 screws inside that will release the complete door . if your want to do the handle use a credit card and insert it between the handle and door to release . but if stainless it some times leaves marks on door . i always remove the doors as one door is ever and i mean very costly.. mm hope this helps mm feed back pls ..
Nov 08, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Door dosent have hole s for reversel
Can you take the doors off and turn them. You may not be able to remove the handles but what about the hinges?
Feb 24, 2010 | Refrigerators
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I have a ksbp25fkss side by side fridge and the door handle on the freezer is loose, but the handle is not the one depicted in the manuel. the handle must be tightened from the back or inside of the door....
you should have trim below and above the handle if not then and its a stainless steel door then there is small round opening on the side of the handle you'll need allen wrenches once you loosen the allen the handle slides up or down then you will be able to tighten the stud post screw then reverse the mounting -----------------be cautious of scratching the stainless steel door when removing the handles
Sep 01, 2009 | KitchenAid KSCS25FKSS Side by Side...
ELECTRIC DOOR LOCKS ONLY LOCK SOME TIMES
if you hit the lock button a couple times, will it finally lock?
If so, then you will need to take door cover off and lube up the connectors as they probably got corroded.
Aug 14, 2009 | 2000 Ford F350 Super Duty Super Cab
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
The door handle is loose and i cannot tight the screws i dont want to call a repair man why would they make it difficult to tight the door handle .it cannot be difficult something to make a dollar this is...
mine was the handle was loose on the door not the coil in the stainless problem . i will try and figure it out my self i will not pay to have the handle tighten
Apr 05, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Removing Door Panels on Sub Zero 532
Hi, there is a metal strip that runs down the middle of each door the entire lenth. It is held on with two magnets. Once you pull that strip of metal off, you will see five screws that hold the door handle on. Remove thos five screws and the entire handle comes free. Slide out the panel and replace the handle, screws and metal strip ion reverse order. Take your time removing the magnetic metal strip as it is a very soft metal and could possibly bend or kink up on you.
Hope this helps. I'm having some trouble locating any company that makes stainless stell to match the appliances. All of the metal companies say the appliance manufaturers have a propriety type of lock on the appliance metal finishes. I also have the 532 model.
Good Luck
Mar 25, 2009 | Refrigerators
Broken exterior door handle,passenger sider ,sliding
Got this idea from mpvclub.com: Get some stainless or aluminum sheet metal screws, drill pilot hole into the handle and into the receiving part behind, then screw in the screw. Do on both sides of handle (get appropriate length screw.) When done, get some putty or hardener to fill in the screw slot, let dry, then sand smooth, then paint with body color. Result is great and inexpensive.
Jan 26, 2009 | 2004 Mazda MPV
Amana ABB2527DEW / ABB2527DEB / ABB2527DEQ Bottom Freezer Refrigerator Logo
26 people viewed this question
Top Amana Refrigerators Experts
Marvin
Marvin
john h
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
