The ice maker on my Maytag refrigerator just suddenly stopped working. The water despeses out the door just fine. I have checked the shut off flat in the ice tray and it seems to be ok. Does not seem like anything is frozen in the trays. thanks
Water valve for ice maker may be bad. there are two valves with one supply line, one valve controls the water dispenser and one for the ice maker. you can ohm out the solenoids, it'll ohm if its good and won't if its bad
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
SOURCE: No ice...different question
Are you able to see if you can push a Q-tip or something up the fill tube line to see if it's frozen up inside there. It happens on certain units. You may need to take the Ice Maker out (easy) to get to the fill tube.
SOURCE: The ice maker stopped ejecting ice. Now no water going to icemaker
hav u cleared the ejection area for any debris and the like?
SOURCE: ice maker stop making ice for kenmore 106.56352500
The ice maker has a problem
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
SOURCE: LG Ice maker
I got the same problem where the plate is cold and the water does not fill - saw this comment from other posting and help. Basically, the ice maker was stalled! Make sure you can see the green light is on, which means you have power. if its lit, press and hold the cube size button until i/m starts to cycle. If i/m runs, but does not fill then your water valve is bad. If i/m will not start then your i/m is at fault.
SOURCE: GE Refrigerator, model PSS26MGPBBB, stop
PROBLEM IS ASSOCIATED WITH THE TEMP SENSOR INSIDE ICE MAKER. I HAVE TRIED TO FIND THE PART, BUT WITH NO LUCK. IT LOOKS LIKE WE WILL HAVE TO PURCHASE A NEW ICE MAKER.
