LG WM1814CW Front Load Washer Logo
D
Donato Posted on Dec 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just Shuts Off
The machine just shuts off with no error codes. When the power buton is selected and any cycle you hear the door lock when start is pressed and as soon as the drum begins to turn it clicks off; no codes. Sometimes is will start and run without issues for 5-10 minutes and then just shut off; no error codes...
Eric Taylor
Level 3:
Master:
  • Master 590 Answers
  • Posted on Dec 29, 2017
Eric Taylor
Master
Level 3:
Master:
Answers
590
Questions
6
Helped
206161
Points
1556
Please call a local engineer as we don't know what type of machine your telling us about eric
5 Related Answers
Anonymous
  • 230 Answers
  • Posted on Jun 06, 2008
SOURCE: Machine won't start, lights are all on and ready to wash
this may be due to heavy load , if there is heavy load then also the machine will not start but the lights will glow
Anonymous
  • 4 Answers
  • Posted on Jul 16, 2008
SOURCE: LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
Paul
  • 381 Answers
  • Posted on Feb 22, 2011
SOURCE: I have a WM2277HW LG washer. I launched a cycle
Replace the hall sensor located in the back. If that doesn't fix it, then you have a problem with the rotor and stator.
Anonymous
  • 1554 Answers
  • Posted on Jul 05, 2011
SOURCE: My LG Tromm front loader
The problem appears to be the direct drive motor located at the rear of the machine. It seems that the drive motor draws too much current when the machine is loaded during the spin cycles. Unplug the machine then remove the rear access panel to access the drive motor and remove the bolt securing the rotor to the drive shaft. Remove the rotor then check and make sure the electrical connections on the motor windings and the Hall sensor are snug and tight. Reseat the connections several times to clean off possible corrosion and dirt built up.
Measure the resistance between each two of the motor winding terminals and it should read almost equally at around 5 ohms to 15 ohms. Also measure the resistance between each these terminals with the windings core and the cabinet which should read infinite (open). Any significant discrepancy in the readings compared to the normal values is an indication of a motor windings problem, replace the stator.
Check the motor and Hall sensor connections to the main control board and ensure they are snug fit if the connections right at the motor terminals including the winding resistances are all good. The problem is with the main control board malfunctioning if all else turns out good; wire harnesses, connections, and motor windings. Replacing the main control board is then the only option.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Sep 29, 2011
SOURCE: For about a month my LG WM3677HW began to not dry
Hello, My Name is Mike, please do me a favor and check out this link I gave you below to see if you can dissect some of your issue of the symptoms, and this might in its self help you with this problem. Please let me know it this helped some. Thanks Mike
Please copy and paste this link into your browser.....
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6333
1helpful
Hotpoint wma48 shuts down anywhere during cycle
which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
My 3 1/2 yr old unit stopped working completely at almost the end of the cycle. When I went to take out the clothes they were still wet, thought it was the spin cycle so I tried that and the machine...
Hello Anne, thank you for allowing me to assist you!
Based on the symptoms you are describing it sounds like the issue could be related to the door switch or control board. However, first let's try recalling the error code by waking the unit and wait approximately five seconds. Then press and hold CANCEL and START/PAUSE key at the same time. Error code should display. With the error code I can help you determine the possible failures.
If the washer does not display an error code, reset the washer. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes, turn the unit on and redo the steps above.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you!
2487 LG front load washer
sounds like a door lock issue , i would replace the door lock if you are not getting any error codes.
door lock error would be a DL
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 • LG WM1814CW
1helpful
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
1helpful
2answers
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
5helpful
2answers
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
