KitchenAid KFP670 Ultra Power Food Processor Logo
A
AFletcher Posted on Dec 11, 2013
Magimix3200, bowl stuck on base
Machine operating fine but can't remove bowl - should release by turning to the left. Appears to be some sort of spring in handle that may have something to do with it - looks as if rod going from handle into base.
2 Related Answers
xalint1
xalint1
  • 152 Answers
  • Posted on Sep 22, 2008
SOURCE: The plastic ? bowl of the processor is stuck
With the food processor I have it will not allow you to remove the bowl unless the top is off.Try take the top off or putting it on.Then remove it from the processor.
Anonymous
  • Posted on Jul 27, 2009
SOURCE: bowl handle doesn't make connection
I had this problem, I finally stuffed a tiny piece of tin foil into the hole the spring is supposed to go into to activate the machine. It works, but it is always on, even if the bowl is not locked into place so I have to be careful. I just store it unplugged.
Kitchenaid kneading blade stuck
Check that the safety lock pin is releasing from the base. It is the thing in the tube down the side of the bowl that the lug on the lid engages with. It stops the motor running with the lid off..
https://www.google.com/search?q=Kitchen+Aid+food+processor+bowl+stuck
2answers
How to take out stuck chef bowl
I've not seen a bowl stuck on one of those unless the chopping blade is jammed on the shaft and preventing the bowl lifting up. Or is the chef bowl a smaller bowl that fits inside the main bowl?
1helpful
2answers
The bowl on my cuisinart food processor is locked in place. How can I unlock it to remove the bowl?
You don't say what model, but all Cuisinarts have a safety interlock built in to the bowl assembly. The cover must be removed from the bowl to release this interlock before you can remove the bowl from the motor base.
1helpful
How do you take bowl off for cleaning
Hope you've worked it out by now, but there are 2 notches at the bottom of the bowl that slot into the base. To remove the bowl, take the lid off and rotate the bowl clockwise so the notches disengage from the base, and simply lift it off/. I assume if you couldn't do this the bowl must have had a lot of gunk stuck in the notches which prevented it from moving - yuk! I put my bowl and lid in the dishwasher - no prob.
Work bowl stuck.
Hello. It will release. Just use a wooden spoon wrapped in a towel to gently tap on the handle until it moves and releases. J.
3helpful
How to disassemble the Sunbeam Oskar processor to wash.
Ours is hard to remove, too. I just hold the base with both hands, then put my left thumb and right index fingers on the parts of the bowl where it attaches to the base. Then push it, if I remember correctly, clockwise. This works far better than gripping the entire bowl.
2helpful
The base is stuck on. I was able to take base off.sunbeam oskar
1helpful
CUISINART FOOD PROCESSOR MP14 WON'T TURN ON ..NOT EVEN THE RED LI
You should not have taken it apart - that unit has a fantastic warranty. Call Cuisinart and get it repaired - don't even hint that you took it apart, or your warranty is void.
jo82 - here is how to test your motor to be sure -
Remove the workbowl completely, plug the base into the wall outlet, turn the machine on, take a pen and press in the little black/dark gray button on top of the base. If you hear spinning, then the motor is fine.
If the motor is fine, put the work bowl back in place with handle facing fromt of machine, lid lined up with bowl, and pusher sleeve with metal element lined up with front of machine.
If the motor test failed, call Cuisinart and get the unit repaired.
-Tha Mp3 Doctor
1helpful
2answers
Safety-rod of bowl does not depress microswitch of Cuisinart processor
Cuisinart does not have the original pieces available, but you can order a replacement work bowl, lid, sleeve, etc that will work from the company. First do a motor test to make sure the motor is still working:
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
How do i remove the blade of of the bowl?
Remove bowl lid first
Then twist bowl to left (as you face front of machine)
Lift bowl up - blades will come with it
Top KitchenAid Food Processors Experts
NOEL
NOEL
john h
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
