SOURCE: clock setting
Press the fourth button from the left (that looks like a tick) then turnthe knob to the right of it to set time as required
SOURCE: Main oven tripping the fuse
probable fault to earth of circular element - gets worse when element hot. you will need a megga to confirm this.
SOURCE: Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
SOURCE: Neff Circotherm Double Oven keeps blowing
I assume that you are fitting genuine elements, as opposed to cheap copy ones..
Make sure the fan is working o/k as well.
You also need to check the temp is correct, for this you need to have a oven thermometer to check it with.
Make sure the connections to the element are o/k as well.
Hope this helps with your problem.
SOURCE: I have a Neff U1721 circotherm oven. The lights
For all Free appliance repair videos visit our VIDEOTUTORIALS
Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
