Question about AOpen Computers & Internet
Startup take to long
Bios no.nt94510j.86a.3659.2oo6.0315.1110
Posted by Hennie Engelbrecht on
James Miller
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AOpen Master
  • 2,226 Answers
Check out drive
Posted on May 11, 2014
Actualizacion de BIOS SA86510A.86A.1024.2006.0504
The BIOS number corresponds to Intel Desktop Board D865GSA. You can find the BIOS at following link
https://downloadcenter.intel.com/download/10671/BIOS-Update-SA86510A-86A-
It was released in 2006. The latest BIOS is at following link and it was released in 2010.
https://downloadcenter.intel.com/download/12687/BIOS-Update-SA86510A-86A-
Aug 10, 2015 | Computers & Internet
I want latest BIOS drivers for INTEL DH55TC desktop board. I've gone to http://downloadcenter.intel.com but the latest BIOS drivers available in INTEL site is TCIBX10H.86A.0048.EB.EXE & Date:1
Those are the latest drivers you can get. Bios updates aren't created on any regular schedule or anything, and eventually they stop updating them altogether when the board is past its manufactured life cycle. They may make another update in the future, but then again they may not.
If you are having an issue with the motherboard that's not been addressed/fixed by the last update, then the only thing you can really do is email Intel and tell them about it. If they get enough complaints about what your issue is, then the probability they will fix your issue and make a newer Bios update will go up. Luckily Intel has more resources/programmers than most other companies in the business and thus your chance of getting a Bios update is better than average.
May 20, 2012 | Intel DH55TC Motherboard
Cannot detect onboard sound plz help me
did you updated the correct firmware for your bios, sometimes faulty updates lead to this post me *********** board model and make
Feb 27, 2012 | Intel D101GGC Motherboard
HOW TO UPGRADE INTEL 945GCLF MOTHER BOARD BIOS. BIOS VERSION IS "LF94510J.64T.0000.2009.0123.1105" & BIOS SOFTWARE VERSION IS AVAILABLE ON SITE IS " LF94510J.86A.0038.EB " WHEN I...
It seem your current version "LF94510J.64T.0000.2009.0123.1105" doesnt have any BIOS ID's which is required to upgrading. Where '0000' should have any version number.
I recommend using DOS environment when upgrading BIOS, this is the safe way flashing BIOS..so download file LF94510J.86A.0278.BI.ZIP here.
Extract all files on USB flash disk which is bootable flash disk. Run files executable on the command prompt and follow the instructions..
Aug 07, 2011 | Intel Computers & Internet
Need advice on pentium d 805 & motherboard gc11010n.86a.0311
In the BIOS (probably in advanced features or overclock menu or the sorts)
you'll need to either find the option to tune down FSB (probably around 200) or your CPU multiplier. CPU speed is FSB*multiplier, so you can yourself calculate the desired speed. If you need any help finding the BIOS menu these functions are in, I could do a little more research, but for now I'll trust you can find them yourself.
I hope this answers your question,
Yannick.
Dec 10, 2009 | Intel Pentium D 805 2.66GHz 533MHz 2MB Skt...
My d101ggc mother bord with p4 procesor and 1gb ram i am using. my pc is restarting and finally i found that their was a problem with bios my bios vertion is gc11010n.86a.0313(after the updation). i wants...
i dont think that it is the bios problem bios work is over when the system is booted it has nothing to do with that it can be hardware conflict or may be RAM
pls check RAM try re fitting the RAM or try alt RAM chips and see if it helps normally it happens in these cases
pls let me know so i can help more
Feb 24, 2009 | Intel D101GGC Motherboard
BIOS
perhaps expand on that. are you trying to upgrade the bios ?
The motto for bios upgrades is if it is working don't fix it till it's broke.
Aug 22, 2008 | Intel Motherboard
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Mar 10, 2008 | Intel D845GVSR Motherboard
Computers & Internet Logo
Top AOpen Computers & Internet Experts
Michael Thomas
Michael Thomas
Joe Goldman
Joe Goldman
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
