Hp designjet 9000s system error
SOURCE: cant not star my printer i get this masage Hp
that means that there is an error with the actual printer. The best thing to do is to take it to where you have purchased the device and they can then see what is causing the problem physically and if its still under warranty they can then swap it out for you
SOURCE: how can i fix system error 11do on hp designjet
System Error 11D0: Cooling Fan Error
Description:
When the Printhead temperature reaches above 43oC, the Printer will check
whether the temperature drops below 43oC during printing. This error will
appear if the temperature does not drop below 43oC after 10 minutes.
Corrective Action: Try the following:
Make sure that the Printhead Cooling Fans are working correctly. If the
Printhead Cooling Fans are not working correctly, replace them.
Make sure that the Printer Cooling Fans are connected and working
correctly.
