SOURCE: i want to install XP in lenovo y510
okie! a question? i have installed windows Xp with Sp3 on my Y510. Now whenever I try switching back to AHCI mode i end up with a BSOD. would it make any difference if i leave it in the compatibility mode? or how can i get it back to AHCI mode
SOURCE: can't find drivers for win 7 64-bit for lenovo y510
Windows 7 is a new platform and every hardware manufacture is developing the driver suits for it.Meanwhile you will have to download the drivers directly from the chip manufacturers site e.g. for sound you can download it from http://www.realtek.com.tw/downloads/.
About the chip manufacturers you can know from the Y510 page where the drivers are there for Vista or XP.
Thanks.
SOURCE: My lenovo S10-2 (Bootmgr)
Follow what was said above by
knindza22
But I would also TRY to load last known Winders boot.
I am assuming you have ONLY Winders on the Machina and it is NOT Dual boot.
SOURCE: lenovo y510 wont start in normal mode (xp)
For the Lenovo to to start in the safe and networking mode, and then not have a display when you attempt to boot it in normal mode, I would follo the these steps:
Boot in networking mode, and then go to the Lenovo site and download the most current display drivers. Since you are able to operate as described above, I would start here first. Once you have successfully downloaded the most current drivers for the video on your system, BEFORE you leave the Lenovo site, check your system against the listed bios upgrades. I believe you may find you need to upgrade your system firmware. If so....download the upgrades you need, and finish the display drivers updates as discussed above, and keep the fresh firmware updates set aside and see if the display driver updates allow you to boot normally.
If so, once you have a normal boot, backup your systems RIGHT away! The next step is to then carefully read the docs about how to update the firmware. Sometimes this will require a floppy drive, if so, you can most likely either pick up a USB one very cheaply or perhaps borrow one. At any rate, make sure your system is backed up fully, and preferable with a restore point, (if you are able with XP?)
Try these measures, if it is successful I would love to hear that from you by way of a testimonial. If you are not - please return here for further assistance. I have additional help for you - but I do not think at this time you have a hardware problem.
Have a great day!!
