SOURCE: I lost my manual for my D-Link AirPlus Xtreme
you try this web site you get the manul http://www.dlink.com/products/?pid=292
SOURCE: IP address
1. if you computer connected to the internet behind the router you can use this command under dos or command prompt.
ipconfig /all
under internet adapter local are connection look for gateway and thats your router IP address,
2. if you still cant access it .
force reset it to default settings
there's a small reset botton at the back of it, use pen to reset it and it will reset to its default IP address
try:
192.168.0.1<-- this is the default for dlink
192.168.1.1
192.168.1.0
SOURCE: How to make my wireless
acess your router http://192.168.0.1
or http://192.168.1.1
then user is admin
passowr dis bleank or admin
then selcet setup of nternet type is with static ip set ip and gateway.
also set security encryption key.
also enable advanced security.
then allow mec adreses of which u want to give internet.
SOURCE: how to connect dlink dwl 3200AP with dlink dwl
make a repaeter mode
and ip would me same range
SOURCE: ihave problem iam make my D-Link AirPlus Xtreme G
if the router or modem has wire if wireless if there then they have the same seciurty option it means same passwork wep
