Sony VAIO VGN-FZ240E/B Laptop Logo
B
Bernardo Posted on Dec 11, 2013
Psvita wet and dont turn on its been 4 months
Install new wet end on waterway 4 hp
split wet end from motor take off cover to impeller unscrew impeller screw should be backwards thread hold back of motor with wrench after screw is out turn the impeller off should be regular threads use gloves or put a screw driver in hole to turn dont break the impeller then remove pump from backing plate then reverse to put back together dont forget seals
Psvita headphone dont work
Did you try them in other devices, Radio, Amp, DVD Player, etc. If they failed on other devices, then take them back for a replacement.
Ok, I bought my son the psvita mega bundle pack... He is currently playing little big planet story mode, but he wants to create his own levels! On the pod view, he cannot seen the create planet, he only...
As with LBP 2 You have to clear the first story quest (first story trophy will pop up) to get access to the community and your moon. The first story quest is more of a tutorial
How do i play moviestar planet on a psvita
download adobe flash from pc
Mar 31, 2013 • Toys
4helpful
2answers
I cannot see psp files on my computer
If you mean you have the files on a drive then go to tools>folder options> second tab, and check off "show hidden files. If you plugged in the psp and can't see it as a drive under my computer this should also help.
Im on my 2nd big buddy and both of them the fan has gone out, the first on went in a week, and this one last a couple of months.
fans
1. oil the bearings,sae 30 or wd40 for places you cant get into.
dont take fan motor apart unelse you realy have to.
dont let your fan motor bearings get worn egg shaped from lack of oil.
2. make sure fan blades not hitting or scraping fan housing and fan blades are securely fastened to fan motor shaft.
3.mr heater fan motor is 12 volts DC , so it may have a segmated comutator and brushes.
I dont know because i have not yet needed to take my mr heater
fan motor apart but i have worked on hundereds of ac fan motors
in the past 65 years.
4. keep fan motors from getting wet. they hate water.
5. keep fans clean, they dont like foriegn materials.
Your specific problem: first fan 2 weeks,second fan 2 months.
how much you use them, are you wearing the brushes down?
Getting fan motor wet? foreign material getting pulled into fan or fan motor? off/on switch work ok. batterys good,battery contacts ok? fan transformer 110 vac to 12 vdc good? fan bearings oiled?
need more info to diagnose properly.
all of the above needs to be checked out to tell whats happened.
fan & fan motor needs to be inspected.
The rinse cycle dont work also the spin cycle
Had a similar problem 4 months ago with our top loader washer.
Our problem was the door/cover closure detection switch.
It had rusted out.
The machine would still empty out,
but the drum wouldn't spin up. Result was a very wet
lump of clothing and the dryer doing 4x duty trying to
dry the stuff.
Got it wet been like it 4 2 months now wont turn on.. but when i charde it the green light lights up 4 chargin
Sorry Buy a new laptop.When a loaptop gets wet it will get corrosive.eventuly nothing will work.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
