Squeeking
That is strange because both rear wheels as they are connected directly to the trans-axle.I would block up the rear of the scooter so the rear wheels are off the floor, run the scooter,does it still squeak. If it does still squeak its probably the braking mechanism or the freewheel mechanism. I use allot of silicon spray in this area. I use my scooter outside allot, moisture gets into this area and can cause problems. I use pure silicon spray. WARNING; do not use WD-40, it will dissolve some plastics. Also wd40 gets sticky after awhile. Pure silicon spray wont harm anything and is EXCELLENT lubricant. Most scooters trans-axles are hard mounted to the frame, they have no suspension, maybe yours does have some sort of suspension, If it does spray all the joints with silicon. Hope this helps
