Question about Lexar Electronics - Others
Micro sd not detected
My micro sd card's (2) wont detect both new lexar 64gb one is 600x other 300x not sure whats going onplease help
5 Related Answers
athouba239
Athouba Sanasam
  • 122 Answers
SOURCE: MY COMPUTER DOES NOT DETECT MY 1GB MICRO SD CARD
check your card reader or check your card into another computer if it works then it is your card's problem if the card does not detect with a new card reader then its time to change the card.
Posted on Oct 23, 2009
Azrael SRL
  • 11800 Answers
SOURCE: hello,my 1GB micro SD card is not show on computer
Buy a new one , that card has died.
Posted on May 11, 2010
Anonymous
SOURCE: My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
Posted on Oct 21, 2010
mastericpr08
Gustavo Ortiz
  • 637 Answers
SOURCE: my micro sd memory card
Maybe the micro is damage
Posted on Nov 03, 2010
josema_sv
Jose Ma DM.
  • 540 Answers
SOURCE: my card is not detected
It would be a good idea to test the memory in another PC, if the problem continues, the SD has a file system that isn't recognized by your operating system or it has a bad file allocation table, if can be read only from a phone, camera or PDA , and it has data, you can use the corresponding device acting as reader connected to PC using its USB cable to retrieve your data from the card.
Posted on Feb 26, 2011
My 128 gb sd card is no longer working after trying to make it adoptable storage in my s7, my phone or computer wont recognize it anymore pls help
64GB and higher capacities need to be formatted with exFAT.
Some help: https://www.youtube.com/watch?v=JA9fp863d-o
A tool for formatting SD and micro SD cards is SD-formatter:
https://www.sdcard.org/downloads/formatter_4/
Oct 23, 2016 | Electronics - Others
How do i format an sd card for my panasonic lumix dmc-tz40?
I have got a Panasonic DMC TZ70 I could not find out using the manual how to format the memory card. I discovered how .. set the mode dial at the top of the camera to MANUAL, then select menu then you can keep arrowing down until you find FORMAT, click yes and it's done.
Jul 22, 2014 | SanDisk 32gb X2 = 64gb Micro Sd Cell Phone...
My laptop(dell) not DETECT lexar 2 GB SD(MULTI-USE).
My first item to Trouble shoot i think would be your media card reader, check in your device manager to see if there are any conflicts in the driver or if a driver is even installed for it. if there is a conflict, go to your pc manufacture website go to support , drivers an download the card reader and reinstall. Also is there any data on the card? and if not has it been formated yet?
May 28, 2011 | Lexar Professional High-Speed 2GB Secure...
I have a lexar micro sd adapter, im putting it in a slot in my computer. the thing is that nothing is popping up. i tried searching for the lexar micro sd adapter in " my computer" but theres...
It appears in My Computer as a Removable Media only if it has a card in it. If it still doesn't appears with a card , even in another pc, then it's faulty, get a new one
Jan 23, 2011 | Computers & Internet
How to format sd micro card FAT 32 system vista home premium thank you philip
- Make sure the SD card is detected
- Go to my Computer
- Right click the SD Micro card -> pick Format
- Select FAT 32 from File System
Oct 26, 2010 | Computers & Internet
My micro sd wont read on my computer or phone & when i put it in the camera it says ''memory card error'' help!
1. If your Micro SD memory card can be detected on your computer, then try to completely format the card.
2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >> Start >> OK / Yes (confirm the request!).
3. If the memory card cannot be detected / readed by your PC, phone, and camera, then that card has become corrupt / unrepairable,
4. You should replace that memory card with a compatible one!
please rate this advice if it helps...tc! :)
Jan 14, 2010 | Electronics - Others
My lg kp500 wont detect my micro sd cards..already tried with several sizes between 1GB-8GB.funny thing is, they all work in my old phone(nokia). im sure i've installed them correctly. any ideas?
Your mobile doesnt support micro SDHC card, it supports only micro SD card, So check whether the card you use is SD and not SDHC
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
My nokia 6500 cant detect my micro sd memory 1gb.. plz help
hi, i got the same problem and got to solve it. Try this...
1. the battery cover must be put on otherwise, the hp won't detect the memory.
2. try to fix the cover or hook by bending it.
Good Luck.!
Feb 18, 2009 | Nokia 6500 Slide Cellular Phone
Electronics - Others Logo
Top Lexar Electronics - Others Experts
Ekse
Bill Boyd
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
