Compaq Evo N800c Notebook Logo
a
amir adam mohamed Posted on Dec 10, 2013
1782 disk control failure / non-system disk or disk error That is all it does
Non-system disk or disk error
Cybertrónica
Level 1:
Filmmaker:
Uploaded 5 video answers.
  • Contributor 30 Answers
  • Posted on May 14, 2014
Cybertrónica
Contributor
Level 1:
Filmmaker:
Answers
30
Questions
0
Helped
27861
Points
65
That means, there's an error reading the files of windows system, or something else to start your Operative System.
Try to reinstall your windows.
If you get errors when you try to install the windows, tell us the error on the installation. It can be an Hard Disk problem and you must replace it.
5 Related Answers
Anonymous
  • Posted on Sep 17, 2008
SOURCE: error messages
You may want to make sure it is the right type, this laptop take the older ide hard drive.
Azrael SRL
  • 11800 Answers
  • Posted on Oct 30, 2009
SOURCE: armada m700 working fine. oneday got message 1782
 disk controller failure - the chip from the laptop's motherboard that's controlling the disks is fried. Nothing you can do - all hd's will be unrecognized - that laptop is dead.
 Buy a new one.
Testimonial: "thanks for a direct understandable answer"
mahhek
Laxman Bisht
  • 662 Answers
  • Posted on Feb 24, 2010
SOURCE: MY LAP TOP MESSAGE SAYS... 1782 DISK CONTROLLER
You are getting this mess because the system is not able to detect a boot partition on the hdd or may be it is not able to detect the HDD itself.
Try to remove the HDD(hard disk) and re-seat it, Also make sure that there is no disk in the CD drive (in case the first boot device in the BIOS is set as CD drive).
Go to BIOS by pressing F10 (system setup) and check if the HDD is detected in BIOS.
Try to run a recovery by pressing F11 on first screen after power on.
Please get back for any further assistance.
Thank you for choosing Fixya
Anonymous
  • 325 Answers
  • Posted on May 09, 2011
SOURCE: Non-system disk or disk error reapl......ENEY
means that it cannot read any information from the first boot device.
normally your hard disk..
however if you have plugged anything in like a penstick maybe, then it tries to boot from that.. so check you simply have not left a penstick or usb device with memory in (mobile phone). in the good old days it was usually somone had left a floppy disk in the drive...but I assume you have not got one of these in it???
if thats ruled out and thats your error. go into the bios (F2) I think but it tells you when you first switch on press [whatever] to enter setup...whatever it is press it.
look for the menu that tells you about your hard disk...MAIN
ignore the red square
but see where it says 1st drive and then a model number...check that there is a model number there if not, theres probably something serious wrong with your Hard disk take it to a repairer or if your confident replace yourself and reinstall windows and all your drivers...plus you have probably lost all the data on there...hope you made backups
if there is a model number there, odds are the Operating system is corrupted, a repairer may be able to save your data (documents pictures) and reinstall OS or repair it. but thats not guaranteed.
http://www.2pages.co.uk
Anonymous
  • 286 Answers
  • Posted on Dec 09, 2011
SOURCE: I am having a problem with the boot of my compaq
First thing to do is enter the BIOS screen. This is the computers built in system configuration. Navigate to the Exit portion and choose "Load Setup Defaults" . Save the changes and exit. The Laptop will restart. If it is still showing, ensure there isn't a disk in the CD-rom. If all of the above doesnt help. Make sure the hard drive hasn't wiggled loose.
How to fix disk controller failure 1782
Try going here http://www.hirensbootcd.org/download/ burn to disk so many useful things.. Run Mini XP
Error 1782 disk controller failure wen i tried tio replace optical drive
It is not connected properly. Try reseating. Check hard drive if possible and was recently removed. Then check BIOS to verify drive was picked by laptop.
I am having a problem with the boot of my compaq aremeda 700. It says 1782 disk controller failuer then non system disk error or disk error, replace and strike any key when ready. I think this all things...
1helpful
Stop the laptop,remove the battery, remove the hard disk and put the jumper located at the rear of your hard disk unit in the CS pins. Then return the hard disk to your laptop and the battery. Start the laptop, go directly to the BIOS and set the following boot order: 1-CD, 2-HD, the rest disabled.  That should be enough.
2helpful
Armada m700 working fine. oneday got message 1782 disk controller failure. have tried removing things. will get message even if hard drive & caddy removed. have reset startup sequence have tried with...
 Buy a new one.
I have a compaq evo n600c laptop which just crashed running windows 98se and now i get error message 1782 disk controller failure followed by non system disk error.I do not have the op disk so i tried to...
Sure, no problem, http://download.cnet.com/Microsoft-Windows-98-SE/3000-18513_4-12296.html - 64k try this site and other related in order to create a system disk and reboot your system. Good Luck
Fehdi
Error messages
1helpful
2answers
Error messages
Try removing the jumper from the harddrive, then restart
or
Take the jumper off restart shut down and then put it back on again
or
remove the CMOS battery from system board and boot once after booting shutdown your system and insert the battery back, again start your system and press F1 next time it won't ask you for pressing F1. reset your BIOS after that (time,date,etc.)
Try these one should work.
Please let me know.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
