Question about Acer TravelMate 600TER Notebook
Clear the Boot-Up Password
How can I remove the Boot-Up Password?
1. I try to find the CMOS Battery, but I can't locate where is it.
    And I found the sw2 below the keyboard, on the main board.
Q: Is the sw2 can help me to do it, or other way that I can solve this problem ^^?
     Thanks!
Posted by Vincent_Chon on
  • Vincent_Chon Oct 18, 2007
    Hello harvester3,
         Thanks for your suggestion, but I'm not in you country, so I can't send the notebook to you. And I've pulled out the battery. Hope I'll success ^^!
         Thanks for your suggestion ^^!
        Vincent
Anonymous
    Scholar:
  • 181 Answers
Laptop bios passwords aren't managed the same way desktop bios passwords are. You won't do any good trying to find a battery (on most laptops anyway) to pull, or a jumper to reset.
Bios password removal is a delicate proceedure, and proof of ownership would need to be furnished before my shop would attempt it. BTW, we have a 100% rate of success, and it's actually a great challenge.
Good luck
Posted on Oct 14, 2007
Removing cmos password on PCG-7134M
1. ) Contact Sony support2.) Providing your the legal owner of the laptop you can try download Hirens boot disk and use cmos clear utility.3.) If you have no fear of taking apart laptop you can try removing cmos battery.. although this method doesn't work on most newer laptops.
Nov 16, 2011 | Computers & Internet
Bios boot password on a Toshiba c655-s5049
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
hope this helps dont forget to vote!
Feb 25, 2011 | Toshiba Computers & Internet
BIOS PASS WORD LOST
To remove the bios password you need to clear the CMOS.
Open your laptop casing look at your motherboard. locate the CMOS jamper it is near the battery. To clear remove the jamper and turn your computer on with in 5 to 10 seconds and turn it off. Reinsert the jamper back to there proper place and try to turn go to BIOS if there will be a password box appear.
You need to open your laptop and look at the motherboard and locate the CMOS battery. Just remove it with in 5 minutes to clear BIOS password.
Jun 26, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
I FORGOTT THE BIOS PASWORD FOR MY NX9010 HP . WHAT CAN I DO?
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
May 25, 2010 | HP NX9010 Notebook
A password bois in thinkpad t60 et merci
Apr 24, 2010 | IBM Lenovo ThinkPad T60 ThinkPad T60P...
Toshiba bios setup password
Apr 18, 2010 | Dell XPS M1210 Notebook
How to reset bios password on inspiron 1150
Apr 18, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
Oct 16, 2009 | HP Smart Buy Notebook
How to break bios password
remove CMOS battery for 1 minute then try to install it back
Jun 08, 2009 | Intel D945GCCR Motherboard
Toshiba Protege 2000 Lost BIOS Password
if you are getting password in the booting of the pc then it is bios password plz check the link
http://www.tech-faq.com/reset-bios-password.shtml
if it is not then try to boot in the safe mode and change the password
Jun 24, 2008 | Computers & Internet
Acer TravelMate 600TER Notebook Logo
178 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
