Posted on Oct 14, 2007
Streaking the copier has started producing copies that are streaked vertically w/ bands of lightness alternating w/ bands of darkness. And that is w/ the manual setting at the lightest it will go: if I used the 'auto' setting for copy lightness, the copies would come out basically black.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 13, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
741
Points
24
Hi
This sounds like it could be a charge corona issue, or an electrical issue. I would clean the corona units up first and see what happens.
If you are still having issues, I know there was an issue once where the black block at the back of the inside of the machine would deteriorate/crack allowing charge to ground. I think the black block makes contact with some connectors at the back of the transport belt unit. You have two electrodes that come down to meet a block in the bottom half.
Anonymous
Level 1:
  • Contributor 69 Answers
  • Posted on Oct 14, 2007
Anonymous
Contributor
Level 1:
Answers
69
Questions
0
Helped
40989
Points
62
Hi im jules_09.his there any error code?if no error code try to adjust the voltage on the exposure lamp,if that does not work can you send me a sample print at [email protected] so i can see the print .
Printer head alignment
Print Head Alignment For Canon printer For more details visit this website: https://www.errorsdoc.com/canon/
Open the printer driver setup window.
Click Custom Settings on the Maintenance tab.
The Custom Settings dialog box opens.
Switch head alignment to manual.
Check the Align heads manually check box.
Apply the settings.
Click OK and when the confirmation message appears, click OK.
Click Print Head Alignment on the Maintenance tab.
The Start Print Head Alignment dialog box opens.
Load paper in the machine.
Load three sheets of A4 size or Letter size plain paper into the rear tray.
Execute head alignment.
Make sure that the machine is on and click Align Print Head.
Follow the instruction in the message.
Check the printed pattern.
Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
When you have entered all the necessary values, click OK.
Note:
If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
(A) Least noticeable vertical streaks
(B) Most noticeable vertical streaks
If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
(A) Least noticeable horizontal streaks
(B) Most noticeable horizontal streaks
Confirm the displayed message and click OK.
The second pattern is printed.
Note:
The third pattern is printed.
Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
How to fix olympus fe-340 streak and peaks verticaly when picture taken
Not sure you can fix this, but most of the time the stripes are produced in a dark environment with one or a few bright lights. The streaks start on the bright light. Most of the time if you shoot the picture the streaks are not on the picture.
You could try to switch the camera to the automatic, or perhaps night scene.
If the streaks are there in normal light, I think your camera is defect.
Vertical black line on scans or copies;
Hello James,
Please click Vertical Bands Lines or Streaks in Copies Faxes or Scans to access the troubleshooting steps that should resolve the issue.
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
All my 8-1/2" x 11" copies are deeply streaked
Chang your UHR and LHR with stripper fingeres, if it is not available at your country change the fusr unit it will resolve your problem feel free to contact me if you have any difficulties and rate me
Pale copies and two vertical white streaks
I'm afraid that regarding pale copies, you are better off checking your consumables (toner, fusers, etc) and then try talking to Toshiba. However, the vertical white streaks can be caused by excess ink and other contaminants on the inside of the printer. If you open the main door to both the printer and finisher (if fitted) and look at all of the visible runners, feeders and other handling devices, try to see if any of them line up with your vertical streaks on a page. If so, try manually rolling them and cleaning them thoroughly. This might help remove some of the streaking (it did on mine).
Hope this helps, Alistair
1helpful
Kodak 5100 aio; banding/streaking problem
You will need a new printhead. If its not under waranty good luck trying to find one.
3helpful
2answers
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
