Can I replace JUST the glass portion of the passenger side mirror without taking the entire mirror off of the door, as taking the door panel off sounds like a nearly impossible task.
I have some good news! I had the same problem with a '90 Honda, and found I could go to e-bay and type in door glass and found a stick-on glass that can be mounted on your broken glass! I bought it and it works!
You can usually just replace the mirror, any commercial auto-glass store has the glass you need. sometimes it is necessary to replace the mirror and its backing (a plastic frame which snaps into the adjustable motor) you don't need to replace the whole mirror unless the housing is broken.
i just replaced the passenger side on mine and this is what i did.
1. on the back side of the mirror housing is a half moon shaped plastic piece. gently remove that from the housing, exposing a portion of the back side of the mirror.
2. disconnect the two wires (remember rt and lf). carefully, with a pry tool, apply pressure on the center of the back side of the mirror, it will pop loose.
3. once the mirror is off there should be a round plastic piece attached to the back side of the mirror. on the passenger side there is a tab in the upper left side. lift up on the tab and slide the plastic piece down...it should slide off.
4. once you have the plastic piece off it goes on the back of the new mirror in the opposite way. you line up the four cross tabs and slide the mirror up until the tab grabs it.
5. put the mirror back in the housing by lining the circle (on back side center of mirror plate) with the center of the mirror housing. genlty apply pressure on the center of the mirror (i had to hit it firmly with the palm of my hand) unitl it snaps into place.
6. once it snaps into place you can reconnect the two wires to the back of the mirror and install the back side plastic housing......DONE
You'll need to remove screws that are by the door handle,
arm rest, under door and side of door and then gently pull back on the
panel as there will also be retaining clips attached and you don't want
to break them. If needed, you can pull back the weather seal
(can't reuse it, but it's not that important) and you will be able to
access everything inside the door
the door panel near the mirror must be removed if not the entire door panel inside u will find 3 nuts to remove to get the old mirror off. hope this helps please rate me
no as a matter of fact it is real simple nowadays...just remove the broken glass and go to the auto parts store and they have another one in a kit that glues right back on to the mirror... good-luck ray
If you need to replace the entire mirror - it's a little involved. First you need to take the upper extension panel off from behind the mirror (black triangle) - just pull it of starting at the top. It will snap back on later. Next - remove the different screws holding the door panel in place (not the ones behind the mirror yet!) One is under the handle (pull it out and pull out the filler panel - small plastic thing that has a hole to pry it out). Then take off the rear red light - also pops off - and remove that screw. Finally - pick up the rubber filler where your fingers pull the door shut and remove these torx bolts.
Now is the tricky part. Snapp off the entire interior panel. It will pop off - but very difficult. It will sound like it is breaking! Start at the outer bottom corner - and use a door panel remover tool - check Amazon or E-bay - to keep from breaking things. Pull it out from all around the bottom and sides and then lift it up over the door lock. It good to have a friend help here. The panel will still be held on by a cable - that is your door release - leave it alone and let the panel hang by it (or better, put a box under it to rest on).
Now...remove the three bolts holding the mirror on - have a friend help hold the mirror while you do this or it will scratch your new car! Since the inner panel is off - you can also disonnect the mirror plus and remove it. It sounds silly - but the only reason to remove the door panel is to unplug it!
Get you new mirror and reverse the steps.
If you are just replacing the glass (non-heated) - get a replacement from the dealer. Adjust the mirror all the way to the inside and reach behind and pop it off. CAREFUL - put tape over the entire glass as it will likely break even more! Remove your connectors if heated - and replace (and reconnect) with your new glass. It just pops back on!
Replacing glass is easy - just be careful of cheap imitations on e-abay). And never use cheap flat glass on the passenger side! The DOT has special requirements for mirror glass - buy it from gmpartsdirect.com or your local dealer.
you have to buy the whole mirror because they are specially made to have better view, and some times there is a little plastic molding inside that snap out to remove the bolts, but some times you have to remove the whole door panel in order to do it.
