Question about 3G Technology Computers & Internet
Gem wk2 flashing screen - 3G Technology Computers & Internet
Ford Focus 2006 turn indicator not working , can't find the fuse where is it.
Principles of Operation
When the multifunction switch is placed in the LH or RH TURN positions, a voltage signal from the GEM is routed to ground. When the GEM detects the multifunction switch in the LH or RH TURN position, the GEM supplies voltage to the appropriate turn lamps in a flashing manner.
When the hazard warning switch is pressed, a voltage signal from the GEM is routed to ground. When the GEM detects a request for the hazard lamps, the GEM supplies voltage to all the turn signal lamps in a flashing manner. When operating correctly, the hazard lamps flash approximately 80 times per minute.
GEM - generic electronic module , body computer !
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect the following for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Hazard switch
  • Multifunction switch
  • Central junction box (CJB) fuse 32 (15A)
  • Bulb(s)
  • Circuitry
  • Generic electronic module (GEM)
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • ISO circuit fault; all electronic units no communication/not equipped, refer to Section 418-00 .
    • No response/not equipped for GEM, refer to Section 419-10 .
    • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs and carry out the self-test diagnostics for the GEM.
  1. If the DTCs retrieved are related to the concern, go to the Generic Electronic Module (GEM) Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, GO to Symptom Chart .
Generic Electronic Module (GEM) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1499 Lamp Turn Signal Left Circuit Failure GEM Go To Pinpoint Test L . B1503 Lamp Turn Signal Right Circuit Failure GEM Go To Pinpoint Test L . B1875 Turn Signal/Hazard Switch Signal Circuit Failure GEM Go To Pinpoint Test M . B2281 Right Turn Switch Short to Ground GEM Go To Pinpoint Test K . B2282 Left Turn Switch Short to Ground GEM Go To Pinpoint Test K .
Feb 18, 2018 | Ford Cars & Trucks
I've got a 2006 Ford Focus, and recently the rear left indicator has stopped working (I have changed the bulb but the new one(s) don't work either) with the other indicators flashing double quick.
The turn signal lamps on your vehicle are controlled by the GEM - generic electronic module . Have the car checked for DTC'S - diagnostic trouble codes . Auto part stores can not check these code's , need a factory or professional type scan tool . These codes (if any) would point to the problem area . They flash faster because the GEM see's a problem and it's a warning indicator something is wrong , they made it like that so you go to the dealer . Principles of Operation
Sep 25, 2017 | Ford Cars & Trucks
All my lights work on my 2005 ford focus except the lower brake lights and turn signals. all fuses are good.
Do you know anything about automotive electronics ?
Stoplamps
The stoplamps are part of the rear lamp assembly. When the brake pedal is applied, the stoplamp switch supplies voltage to the generic electronic module (GEM) and the high mounted stoplamp. The GEM then supplies voltage to the rear lamps.
Turn Signal Lamps and Hazard Warning Lamps
The turn signal lamps and hazard warning lamps system consists of:
  • Hazard switch
  • GEM
  • Turn signal lamps
When the multifunction switch is placed in the LH or RH turn positions, a voltage signal from the GEM is routed to ground. When the GEM detects the multifunction switch in the LH or RH turn position, the GEM supplies voltage to the appropriate turn lamps in a flashing manner. When operating correctly, the turn lamps flash approximately 80 times per minute.
When the hazard warning switch (located in the upper part of the center console) is switched on, a voltage signal from the GEM is routed to ground. When the GEM detects that the hazard switch is switched on, the GEM supplies voltage to all the turn signal lamps in a flashing manner. When operating correctly, the hazard lamps flash approximately 80 times per minute.
Do you know how to test electrical circuits with a DVOM - digital volt ohm meter , how to read an use a wiring diagram to pin point locations in a electrical circuit for testing B+ voltage an ground ?
Free wiring diagrams
http://www.bbbind.com/free_tsb.html Enter your vehicle info . year ,make , model an engine size . Under system click on lighting ,then under subsystem click on turn signal lamps . Click the search button then each blue link , one at a time .
Electric Testing Techniques You Need to Know
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
May 07, 2017 | Ford Cars & Trucks
4x4 low light on car will not move
The electronic module (located behind the glove compartment) controls the operation of the transfer case in response to inputs from the electric shift motor, 4x4 mode switch, CPP switch, BPP switch, DTR sensor, throttle position output from the PCM, front and rear OSS sensors, and the VSS. Do you know what DTC'S Are ? Diagnostic trouble codes !
P1804 4WD High Indicator Circuit Failure GEM GO to Pinpoint Test C . P1806 4WD High Indicator Short to Battery GEM GO to Pinpoint Test C . P1808 4WD Low Indicator Circuit Failure GEM GO to Pinpoint Test C . P1810 4WD Low Indicator Short Circuit to Battery GEM GO to Pinpoint Test C . P1812 4WD Mode Select Circuit Failure GEM GO to Symptom Chart. P1815 4WD Mode Select Short Circuit to Ground GEM GO to Symptom Chart. P1820 Transfer Case CW Shift Relay Coil Circuit Open or Short to Ground GEM GO to Pinpoint Test B . P1822 Transfer Case CW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1824 4WD Electric Clutch Relay Circuit Failure GEM GO to Pinpoint Test A . P1826 4WD Electric Clutch Relay Short to Battery GEM GO to Pinpoint Test A . P1828 Transfer Case CCW Shift Relay Circuit Failure GEM GO to Pinpoint Test B . P1830 Transfer Case CCW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1836 Transfer Case Front Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1837 Transfer Case Rear Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1838 Transfer Case Shift Motor Circuit Failure GEM GO to Pinpoint Test B . P1846 Transfer Case CONTACT PLATE "A" Circuit Failure GEM GO to Pinpoint Test B . P1850 Transfer Case CONTACT PLATE "B" Circuit Failure GEM GO to Pinpoint Test B .
P1854 Transfer Case CONTACT PLATE "C" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1858 Transfer Case CONTACT PLATE "D" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1866 Transfer Case Maintenance Required (GEM Only) (4-wheel drive operation can be restored by clearing the DTC and cycling the ignition.) GEM GO to Pinpoint Test B . P1867 Transfer Case Contact Plate General Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1874 Automatic Hall Effect Sensor Power Circuit Failure GEM GO to Symptom Chart. P1875 Automatic Hall Effect Sensor Power Circuit Short to Battery (GEM Only) GEM GO to Symptom Chart. P1891 Transfer Case Contact Plate Ground Return Open Circuit GEM GO to Pinpoint Test B Your best bet , take it to a qualified repair shop
Apr 04, 2017 | 2002 Ford Explorer
My 99 expedition won't stay out of all wheel drive I changed the transfer case motor and now it stays I awd for about 10 minute then kicks back out and then the 4x4 light flashes and then it is ok until...
The 4X4 system on your vehicle is computer controlled , GEM module . generic electronic module . The four wheel drive mode switch is a low voltage input to the GEM module . The GEM energizes relay's to control the mode as depicted by input from the mode switch an torque on demand relay an someother inputs . Probably has DTC - diagnostic trouble codes stored in the GEM module .
Transfer Case -Automatic Four-Wheel Drive (A4WD) The automatic 4-wheel drive transfer case system consists of the following:
  • automatic 4WD indicator light
  • brake pedal position (BPP) switch
  • torque on demand (TOD) relay
  • front output shaft speed sensor
  • generic electronic module (GEM)
  • 4WD high indicator light
  • 4WD low indicator light
  • 4WD mode switch
  • rear output shaft speed sensor
  • shift position sensor
  • throttle position output (TPO) from the powertrain control module (PCM)
  • transmission range sensor P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure GEM REFER to Section 413-01 . P1806 Transmission 4-Wheel Drive High Indicator Short Circuit to Battery GEM REFER to Section 413-01 . P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure GEM REFER to the Symptom Chart. P1815 Transmission 4-Wheel Drive Mode Select Short Circuit to Ground GEM GO to Pinpoint Test C . P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure GEM GO to Pinpoint Test B . P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit to Battery GEM GO to Pinpoint Test B . P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure GEM GO to Pinpoint Test A . P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit to Battery GEM GO to Pinpoint Test A . P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure GEM GO to Pinpoint Test B . P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit to Battery GEM GO to Pinpoint Test B . P1836 Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure GEM GO to Pinpoint Test A . P1837 Transmission Transfer Case Rear Shaft Speed Sensor Circuit Failure GEM GO to Pinpoint Test A . P1838 Transmission Transfer Case Shift Motor Circuit Failure GEM REFER to the Symptom Chart. P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure GEM REFER to the Symptom Chart. P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure GEM REFER to the Symptom Chart. P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure GEM REFER to the Symptom Chart. P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure GEM REFER to the Symptom Chart. P1866 Transmission Transfer Case System Concern - Servicing Required GEM REFER to the Symptom Chart. P1867 Transmission Transfer Case Contact Plate General Circuit Failure GEM REFER to the Symptom Chart. P1874 Transmission Automatic Hall Effect Sensor Power Circuit Failure GEM GO to Pinpoint Test A . P1875 Transmission Automatic Hall Effect Sensor Power Circuit Short to Battery GEM REFER to the Symptom Chart. P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit GEM REFER to the Symptom Chart. P1892 Trans. Automatic 4-Wheel Drive 4X4 Mechanical Lock Output Circuit Failure GEM GO to Pinpoint Test B . P1893 Trans. Auto. 4-Wheel Drive 4X4 Mechanical Lock Output Short to Battery GEM GO to Pinpoint Test B .
  • Your best bet , take it to a qualified repair shop .
Feb 26, 2018 | Cars & Trucks
We have a 2001 Ford Escape with a small problem. The remote key fob locks the doors and unlocks the doors but the lights don't flash anymore when you lock the door. The horn also won't honk after hitting...
I think you need to reprogram the module, you deleted the horn chirp and light flash confirmation. he dealer can reprogram for you.
Customer Preference Items NOTE: If using the WDS, select Module Configuration and Programming, then follow the screen prompts.
NOTE: Make sure module is listed as supporting customer preference items and supports the specific item to be configured in the Module Configuration Index in this section.
  1. Select Service Bay Functions on the diagnostic tool.
  1. Select the module that contains the customer preference item to be programmed. Refer to the Module Configuration Index in this section.
  1. Select Customer Preference Items on the diagnostic tool.
  1. Select Module Option Content.
  1. Select the item to be enabled or disabled.
  1. Enable or disable the item as necessary to reflect the customer preference.
Power Door Locks
The generic electronic module (GEM) controls the power door lock and keyless entry system. Lock and unlock operation is achieved through the use of internal relays in the GEM. The relays are all door lock, all door unlock and driver door unlock. The normal path of the relays is to ground.
Pressing the door lock control switch to lock or unlock sends a ground signal to the GEM. The same GEM pin is used for unlock and lock input. The unlock signal is a direct connection to ground. The lock signal is altered by an internal resistor in the door lock control switch. This varied resistance identifies lock or unlock command to the GEM.
The door locks can also be controlled by the door key cylinder switches. For the liftgate door lock switch, turning the key to lock or unlock sends a ground signal to the GEM. The GEM will then ground the all door lock or all door unlock relay supplying voltage to the actuators. Turning the driver door key cylinder to the lock position sends a ground signal to the GEM. The GEM will then ground the all door lock relay supplying voltage to the actuators. Turning the driver door key cylinder to unlock sends a ground signal to GEM. The GEM will ground the driver door unlock relay and supply voltage to only the driver door actuator. If a second unlock ground is received within three seconds of the first, the GEM will ground the all door unlock relay supplying voltage to the passenger door actuators (if 2-stage unlock is equipped).
Keyless Entry
The keyless entry remote transmitter sends a signal that is received by the GEM internal antenna. Depending on the signal received, the GEM module will ground the appropriate internal relay and lock all doors or unlock the driver door. If the unlock signal is received again within three seconds of the first unlock, the GEM will ground the internal all door unlock relay unlocking all doors. The lock and unlock relay output to the actuators is controlled by the GEM, the same as power door lock operation from the control switch.
If the signal received is for the panic button, the GEM will cycle ground to the park lamp relay coil and horn relay coil. The park lamps and horn will continue to cycle until the panic button is pressed again or the ignition switch is turned to the RUN position, or after the timer expires.
Dec 17, 2009 | 2005 Ford Escape
I need an instruction manual for my RCA Clock Radio Model RP3750A. Can't turn off the alarm - want radio to come on with the radio and not the alarm.
There are three buttons under the heading "Dual Wake", WK1, Cancel, WK2. The WK buttons refer to the two wake time settings you can have. Press Cancel and then WKx. That will turn off the alarm. If you press WKx more than once, it will cycle through small symbols on the bottom of the screen with the number x in front of them. First symbol means it will have a sound alarm for alarm x, second symbol means it will have a radio alarm and the third symbol means it will play the CD to alarm. You set the time for alarm with the slide switch at the back of the unit, selecting WK1 for alarm 1 and WK2 for alarm 2. You can have both alarms active at once, or either one singly.
Nov 15, 2009 | RCA Audio Players & Recorders
Computers & Internet Logo
54 people viewed this question
Top 3G Technology Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a 3G Technology Computer and Internet Expert? Answer questions, earn points and help others
