Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Not Draining My machine is not draining? What I can do PL?
Posted by SANTOSHs on
Prem Mulberry
  • 94 Answers
Your pump, or the hose between the drum and pump, might be clogged.  Check it out.  You might find coins from unemptied pockets.
Posted on Oct 14, 2007
Digi marine videocon water not draining pl help
You need to run spin program again, it may need doing several times. Usual cause is over fill machine with washing.
Mar 04, 2016 | Washing Machines
Front load washer vibrates while draining
Plug off the mains from the wall socket. Open up the top of the washer, look to see if any springs supporting the drum are broken. Next check shocks below (known as dampers). If they pump too freely, should be replaced. Parts can be obtained searching ads on this site, Fixya
Pl click helped, if helped.
Apr 09, 2013 | Whirlpool Washing Machines
Frontloadernot draining
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a hose there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
Pl click so if helped
Apr 08, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Does not spin
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl click so.
Apr 04, 2013 | Washing Machines
Washer tub does not turn after it has let the water in
If helped pl say so.
Mar 27, 2013 | Frigidaire Washing Machines
Water will not drain out of drum
Mar 24, 2013 | Frigidaire Washing Machines
Not draining all the way
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl give me a very good rating for the long awaited free help!
Jun 07, 2010 | Kenmore Elite 45986 Front Load Washer
Fisher and paykel gw509 not draining, pump is clear
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Mar 04, 2009 | Fisher Paykel EcoSmart GWL15
Drai not working
Pump is broken most likely check your drain filter it may have too much debris in it also is it leaking any water. if so the tube to the drain my be ruptured
Feb 07, 2009 | LG WM-2277HW Front Load Washer
Will not finish draining
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (refer manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Jan 13, 2008 | GE WBSR3140DW Top Load Washer
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
69 people viewed this question
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
