Kenwood KD-291RC Turntable Logo
A
Anonymous Posted on Dec 11, 2013
Tonearm won't play last track - Kenwood KD-291RC Turntable
Turntable skips regularly
Once adjusted to the correct weight for the type of cartridge then the arm should only jump on a bad record. If it keeps on jumping then either there is something wrong with the platter, being warped or a bad matt. Or there is something in the mechanism that is causing the jumps. Either of these two causes is possible if it does it in the same position on two different records.
MAKE MY TONEARM STOP SKATING
It's possible your weight adjustment has been mis-adjusted since you last used your turntable. On the tonearm, there should be a weight adjustment wheel. Turn this all the way towards the needle (IN). Now, adjust it backwards until there is no resistance in the tone arm - this is your zero point, reset the wheel on the weight adjustment knob to read 0. Now, adjust it forward to 3 grams of downward pressure. This is usually the minimum amount of force needed on a record. If it still skates at this setting, adjust it with gradual amounts of greater force until the skating stops.
Sony PS-LX55II Tonearm Doesn't move when playing
Is there an antiskate or skew adjustment and also a way to set that counter weight? If any of those are wong then it wont work
My arm on my JVC L-A11 won't lft when it should at the end of the record and won't go back to the seat without hitting it and returning to the record. I played with the screws on the pivot by
Hey, I had the same issue. The tonearm returns and then is pulled off the stand back towards the record, instead of settling on the stand.
The problem is that a bit of spunge on the lever pushing the tonearm black has decayed and turned sticky, pulling the arm back slightly when the mechanism resets after returning the tonearm.
Do yourself a favor and get the service manual from vinylengine.
Remove the platter & lock the tonearm in place.
Now, flip the turntable over and open it up. Locate the return lever with the sticky black piece of spunge and either replace it or tape it over with a loop of electrical tape and that should fix your problem.
If you played with the screws on the tonearm pivot on the outside, can't help you there..
1helpful
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
I have an older QL-45 turntable that needs tone arm adjustment- I don`t know how to set the weight so it doesn`t lower down to album so hard or heavily
I can't find the specific turntable. Who makes it?
This should work with some modifications for your specific controls...
Make a note of the tracking force setting.
Make sure the turntable is level.
Set the Stylus Pressure/Tracking setting to 0.
Dial in the prescribed tracking force on the Stylus Pressure/Tracking control. Play records.
When i play a record it skips and when i play it on another turntable the same record doesnt skip
Hi, most likely a worn stylus or the tracking weight is set too lightly. Adjust the balance weight at the back end of tonearm forward slightly. If no weight adjustment available put a very small coin on the end of tonearm above the stylus. [email protected]
1helpful
45 and 33 sound slow
Here's a procedure for setting the tonearm...
Unplug the power to the turntable and place it on a perfectly level surface.
Set the Tracking Force and AntiSkating to 0.
Manually rotate the platter Clockwise a few turns to disengage any cueing mechanisms.
If you don't have a Stylus Tracking Force Gauge. Dial in the prescribed tracking force and a corresponding anti-skate reading. Play records.
2helpful
The belt that is under the plate on my kenwood kd21r if off how does it go on can you send a diagram and to balance the wts how do I know the proper no's?
I don't have anything on that model but general advice would be to...
Try to grab the belt with something soft without sharp edges - say, a loop of yarn or ribbon. Rotate the opening in the platter over to the drive pulley (generally about the 7-8 o'clock position when viewed from the front) and using the ribbon gently stretch the belt over it. If it catches remove the ribbon and manually rotate the platter clockwise about 5-10 turns to seat it and reset any cueing mechanisms. If it's still on and tensioned replace the plate and go to the balancing act.
Set the Tracking Force to 0.
3answers
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
