Question about Car Audio & Video
Cant find a harness to plug into the back of a Dual XD250 RADIO.
I have a 94 Ford Ranger and I bought the Dual XD250 radio to put in it. I have searched the internet over and Walmart too for a wiring harness that will plug into the back of this radio.. CAN'T FIND ONE PLEASE HELP
Posted by Jason T on
Steven Brandon
    Master:
  • 461 Answers
You won't ever. They make a universal harness. You should have a wire harness for your new radio only that was included with the radio. It should plug into the new radio and the other end will just be wires. Then you will need to go to a parts store, ( AutoZone, Oreilly's, Advance Auto, Etc) and but a radio wire harness for your truck. It will have a connector or two that plug into the harness that plugs into the back of your stock radio and the other end will be just wires. you will then connect the two harnesses together by matching wire color. ( EG: Purple to Purple, Gray with black stripe to Gray with black stripe, etc)
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Posted on Dec 11, 2013
5 Related Answers
jackiaria
Jack Iaria
  • 350 Answers
SOURCE: Need a new wiring harness for my Dual XDMR7710
Look in your local phone book yellow pages under stereos for a local (not big name) stereo installation store (there will be one) and go there.....you will thank me!
jack
Posted on Feb 22, 2009
Marty marty
  • 883 Answers
SOURCE: wiring color codes for ford 2002 f250 radio
I can email full diagram to your email address...just post it here. I can tell you that power wires are:
1.) memory power (all times) is light grn / violet
2.) power in start position is red / black
3.)power w/ acc. delay is pink
4.) ground is black / light green
Posted on Nov 18, 2007
Anonymous
  • 625 Answers
SOURCE: wiring-audio system-1989 ford crown victoria
go to an autozone or advance auto parts store and find a haynes auto manual for your car. electrical diagrams are in back of the manual.
Posted on Dec 07, 2007
Anonymous
SOURCE: wiring harness on my 94 Ranger
I have a 94 Ranger XLT extended cab. Here are the power/ ground connector pinouts and wire colors as shown in the factory service manual:
Pin 1 LG/Y Radio Memory Power (B+)
Pin 2 BK Ground
Pin 3 Y/BK Power (Hot in RUN or ACCY)
Pin 4 LB/R Illumination (dims with dash lights)
Pin 5 O/BK Illumination (does not dim)
Pin 6 BK/LG Ground
From the diagrams, looks like either ground will work.
Hope this helps.
Posted on Jun 01, 2008
Anonymous
  • 19 Answers
SOURCE: need a radio wire diagram for 1989 ford mustang 5.0
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Posted on May 11, 2009
How to install a Kenwood kdc 138 in a 1992 Ford Escort LX?
if its anything like my 92 ranger you take the dash apart around the radio and the stereo should unscrew, in my ranger the new cd player went in without any extra harness as it was the same size as the stock, if not you can but harnesses to go where your old stereo did, to connect the speakers you can buy a ford wiring harness from walmart or any store with an audio department. these plug in to your vehicles wiring harness so you don't have to cut it out, after that you simply match colours from the wires of the new cd player to the wiring harness
Dec 25, 2013 | Kenwood DISCONTINUED - KDC-138 In-Dash CD...
Should i have any spare wires when hooking up an after market car stereo
Yes, It's a very good possibility that you will have a few wires left over. Normally a wire for an aftermarket amp to be triggered on when you turn your radio on and possibly a power antenna or a dimming function that dims your radio lights when your headlights are on. It of course always depends on if you have a power antenna or not, or if you have an aftermarket amp or not or if you have the dimming feature on your car or not. These wires don't apply to everyone.
You will just match the colors between the wiring harness that came with the DUAL radio and the interface adapter that goes to your car. Make sure you use **** style crimp connectors. If not the wires could come loose or cause a popping noise or cause the radio to turn off while driving.
Other than that, installing an aftermarket radio is mostly matching the colors up between the two harnesses and crimping the wires together.3_6_2012_2_31_36_am.jpg
Mar 06, 2012 | Cars & Trucks
Dual xd1222 radio fit a 97 stratus wire harness
Basically the radio will fit but since harness differs between some chrysler products, you need to find the pigtail that will fit the Dodge harness and give bare wires to connect the Dual's respective wires. An example of this can be seen at http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/2669860/vpcsid/0/SFV/30046
I have found similar pigtails at Walmart, Best Buy, and some autoparts stores. Crutchfield includes all this based on your purchase - just a thought.
Feb 12, 2012 | Dual Electronics XD1222 Car USB Player
I got a 1998 ford expedition eddie bower and im trying to install a radio i just bought and i need to know the colour coding from the car eglike power wires and speaker wires
just get the harness kit from a sound shop/bestbuy/walmart. it plugs into your car harness and has wire colors that match all the wires on the radio. it makes it fool proof and a breeze.
Oct 07, 2010 | Car Audio & Video
Wiring for stereo in 94 ford explorer
Sounds like you have the Premium Sound system. The main power plug is long and probably black, the other plug is square with a grey round cord coming out correct?
You can either take your power harness back and get the correct one ( a little more expensive) or run ALL 4 sets of speaker wires back to the right rear quarter panel. That is were the OEM amp is mounted and taking that panel out requires you to remove the top and bottom tailgate trims, a dozen screws, the seat belt D-ring and 4-5 plastic push clips that will probably snap off...:( Also, this will not make the OEM subwoofer work.
From 20 years experiance in this biz, save the time, spend the extra 30$ or so and just buy the correct connector. Check MetraOnline.com and search there.
Scott
Apr 16, 2009 | Dual XDMR7710 CD Player
95 FORD RANGER NO INST. PANEL LIGHTS AND PARKING LAMPS
you might have blowed blulbs check that also there might be what is called a fuse link in the wiring
Mar 15, 2009 | 1995 Ford Ranger Supercab
New Car Radio, New Harness but no power, Nissan P/U '95
here is the factory harness wires and what they do, recheck thayt it all matches up.
1995 Nissan Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Mar 10, 2009 | 1995 Nissan Pickup
Wiring harness on my 94 Ranger
Pin 2 BK Ground
Pin 6 BK/LG Ground
Hope this helps.
May 30, 2008 | Car Audio & Video
Car Audio & Video Logo
278 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
