Why won't the closed caption work when I have the HDMI cable hooked up through my cable box. It will work when I use the cable that is hooked up from the cable box Coax cable, but not on the HDMI.
Are you using the cable box settings (or remote) or your TV's remote to select the closed captions. When you use the HDMI cable, you need to enable the captioning on the set top box. The TV can only interpret the CC if the signal goes through the tuner (coaxial cable input). It's a matter of how they built the hardware; the cc interpreter is part of the tuner.
Which cable provider do you have? I know with some providers, there isn't a direct CC button on the remote. With them you need to go through the Settings menu to enable the closed captions. If you add a comment with your provider, I may be able to help you enable the CC if there isn't a CC button on the cable remote.
I hope this helps.
SOURCE: closed caption problem
I had the same issue... here's what I did. If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning. This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area. Hope this helps!
Evan
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
SOURCE: Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
SOURCE: I HAVE CABLE BOX HOOKED UP THRU HDMI CANNOT GET
try dropping down to component or composite cables and see if it works.
SOURCE: HDMI cable hooked up, now CLOSED CAPTIONING is stuck on!
It has got to be the box. I would try to contact Scientific Atlanta if any way possible. The TV doesn't choose what inputs it shows CC.In other words, it would show it on all Inputs if it was the TV. Good luck and Thanks
