Question about Mad Catz Radio Communications
How do i hook up kundi headset to ps4
Cant hook to ps4 the box says it does but when you open no instructions for ps4
Posted by Rick Williams on
2answers
I need help hooking up my samsung blu ray 3D model#HT-H4500 to my samsung television but i have no remote for the blu ray and cant hook it up to same wifi..plus i have a ps4 on top of everything.
Either track down the original remote for the model, or get a universal one, try and get the type that searches for the code automaticly otherwise you will be hunting around for the remote code that is correct for it.
I cannot connect the headset to the ps4 and cannot here the audio from the ps4 on the headset
have you connected a ps4 compatible headset. if not they sell peices to put in the jack in order to do so
How to fix a ps4 that needs a software update via usb
First, from your computer click the Download Link
to download the latest PS4 Update. Make sure you don't rename the downloaded file.
After download, plug your USB onto you Computer. Open the USB and make a folder inside named PS4 (you need to use Uppercase letters). Inside that folder create another folder named UPDATE. Then, just take the PS4UPDATE.PUP file you downloaded from the provided link and put it inside the UPDATE folder.
After that you just connect your USB with your PS4, and then from the Main Screen of your PS4 go to Settings -> System Software Update and just follow the instructions on-screen.
PS: Make sure you DO NOT turn off the console or remove the USB from the PS4 while the update is taking place, otherwise the system may be come temporarily or permanently damaged.
Download Link
http://dus01.ps4.update.playstation.net/update/ps4/image/2015_0625/sys_4f1c6d8597242ff346612773ffbc10ad/PS4UPDATE.PUP
1helpful
I bought a Dreamgear wired headset and for 2 weeks it worked fine, all of sudden the mic stopped working. I can hear others and the game but they can not hear me. What can I do?
Most of the time these problems can be attributed to the jack that is plugged into the unit. The problem could be in your headset's plug or even in the ps4's receptacle. Make sure the jack conaxts are clean. These jacks are also prone to broken connections because of pulling on cords. You might try to return the headset at place of purchase and explain your problems. Dust build up inside the unit can also affect contacts.
My sony pulse headset works fine except every once in awhile it cuts out (will be talking in group then sound cuts off cant hear or be heard) for about 30 sec then works again. batterys not low, blue light...
I was having this issue while using this headset on my PS4. I bought a small,2ft USB extension, to move it away from the PS4 console by about 2 feet and now it works perfect. It was something about the interference from the remote controls. Hope this helps.
Headset cutting out
3helpful
Key/Password
THE PASSWORD IS 0000
(THE NUMBER 0 FOUR TIMES)
2helpful
2answers
Trying to hook up my jabra bt125 BT to my sanyo katana dlx
Before the search you need to hold down the power button on the headset.Keep it held down until it stops flashing,the PS3 should be able to read it.My problem is that I lost my instruction manual and don't know the pass key.Can anyone help me there?
Radio Communications Logo
Top Mad Catz Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
