It sounds like you have a wine cooler with two temperature zones, and one of the zones is either over-temperature or under-temperature. The beeping and flashing light on the right side indicate an error or warning. The left side flashing on and off may mean that it is trying to regulate the temperature in that zone.
Unfortunately, it is not possible to shut off just one side of a dual zone wine cooler. The best course of action is to address the issue that is causing the beeping and flashing light. Here are a few steps you can take:
- Check the temperature: Make sure that the temperature in both zones is within the desired range. If the temperature is too high or too low, adjust it as needed.
- Clean the condenser: Make sure that the condenser is clean and free of dust and debris. A dirty condenser can cause the wine cooler to overheat and trigger an error.
- Check the door seal: Check the door seal on both zones to make sure it is tight and free of damage. If the door seal is damaged or not tight, it could be allowing warm air into the wine cooler and affecting the temperature.
- Check the fan: Check the fan to make sure it is working properly. If the fan is not working, it could be causing the wine cooler to overheat and trigger an error.
If these steps don't resolve the issue, it's possible that there is a problem with the wine cooler's control board or thermostat. In this case, it may be best to consult with a professional for repair.
Remember, it's important to maintain a consistent temperature in your wine cooler to ensure that your wine is stored properly and protected from temperature fluctuations. text me on +233557248347
