Digital Mind Corporation iQ Sound SC-PMP2225 MP3 Player Logo
Question about Digital Mind Corporation iQ Sound SC-PMP2225 MP3 Player
INSERT USB LINE AND PRESS OK KEY TO USE USBDISK
INSERT USB LINE AND PRESS OK KEY TO USE USB DISK
2answers
How do i fix error 98.01.01 on a HP Laser Jet 600 M603
http://www.fixya.com/support/t19504856-98_01_01_printer_error_m603_printer
RESET TO FACTORY SETTINGS
What type of Laptop ? and operating system on it ?
Restoring your laptop to factory settings can take up to an hour to perform, depending upon the type of laptop and operating system on your machine. Prior to performing a system recovery, you should remove any external peripherals, such as ExpressCards, PC Cards, and USB-connected printers and hard drives. Turn on the laptop. Press the "F8" key until the "Advanced Boot Options" screen appears. Select "Repair Your Computer" using the arrow keys. Press the "Enter" key. Choose your "Language," then "Next." Login with an administrator-level username and password. Click "OK. Select "Dell Factory Image Restore," then "Next." Tick the check box next to "Yes, reformat hard drive and restore system software to factory condition." Click "Next." Click on "Finish" after the computer has concluded the factory restoration. b> Restore on an HP b> Insert the HP recovery disk. Restart the computer, and press the "F11" key. Press the "F" key to "reinstall factory settings." If your computer's operating system is damaged, you may only see "perform a full system recovery" as an option. In this case, press "R." Insert any disks if prompted by the restoration program. Otherwise, permit the computer to restart as needed. b> Restore Via Disks (Generic) b> Insert the "Recovery Disk" or "System Recovery Disk." If you have more than one disk, make sure you insert "Disk 1" or "Part 1." Press any key to boot from CD if prompted to do so. Choose a "Full System Restore," "Restore Factory Settings," or another option worded similarly. Confirm that you want to perform the restoration. Press "Next," "Yes," or "OK," as needed. Press "Finish" or "Restart" when prompted by the computer. Hope this helps.
Will not start
A brand name and model with operating system would be nice so someone could be precise. ?
1helpful
2answers
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
FORMAT NEW HD
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
1helpful
Whenever i insert my pen drive and try to open it it says insert drive.its a 8gb transcend pendrive unable to open or format it. It says insert disk.
Do one thing download the transsend s/w from website and try to formate the pendrive
Otherwise instal the USBDISK andi virus and delete the some file from that pendrive.
All the replacement burners I see are the H pattern,mine is straight and I don't see one listed.where do I find the right burner for my magnum 240 grill
i have one digital media player make blu sens he is show the message on screen insert usb line and press ok key to use usbdisk, press other key to cancel usbdisk. I am how to slove this
2answers
Mp4
I dont how to download music to my MP4 from the Internet and also from the media center.
ANKO MP3/4 Player Supposed to Show MPEGS, but Doesn't
When i turn off and turn on player it is saying "insert usb line to use usbdisk press any key to restart. then this is display on the screen "usb disk".
Problem is it is not loading u
I need help
Go into your bios, with whatever button it tells you to push. In there, look for anything that resembles Startup... Theres alot of menus I know, just use the arrow key to look through.... Once u see the start up menu, make sure the Harddisk is 1st (or in some bios, it has to be at the top of the list). To do this, there is a legend at the bottom (or top) of the screen that tells you which each computer key does for these menus. Use this, then, once its 1st (or at the top) of the other options, (other options being cd/dvd, usb, floppy, etc, varies computer to computer), push the save and close key (which again, is on the legend). Tell me if this works please>.<
Top Digital Mind Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Digital Mind Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
