Whats the answer?
SOURCE: I am using my Casio
Display Format To change the exponential display format, press the [MODE] key 3 times. Fixed number of decimal places: Press 1: Scientific Notation: 0 Press 2: SCI: 0 Press 3: NORM You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1 To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2] [=]. This will return the calculator to the following settings: Calculation mode COMP Angle unit Deg Exponential display format Norm 1 Fraction display format a b/c Decimal point character Dot Percentage Calculations
SOURCE: how to remove the grad mode from my canon f-710?
Grad is a unit of angle. The angle unit affects only the results that involve trigonometric functions and their inverses. It cannot affect the display of results in exponential format (scientific).
Change the angle unit to degree or radian if you want.Disable the scientific or engineering displays by using FIX or Normal (floating).
1) Multiplication inside the log can be turned into addition outside the log, and vice versa.
2) Division inside the log can be turned into subtraction outside the log, and vice versa.
3) An exponent on everything inside a log can be moved out front as a multiplier, and vice versa.
Display Format
Press 2: SCI: 0
Press 3: NORM
