Several lights have flashed at different times on the dashboard. Engine light was flashing, but is not on anymore. The slip light/VDC is on continuously. Now the oil light flashing. We had the oil changed about 3 months ago and seems to have not lost any oil. Help .
Did you check the oil now is it basically full? Sounds like traction control but def check oil
Testimonial: "Is there a way to check the VDC/slip light to see if it is a real problem. Oil/filter changed about 3 months ago. This is the order this mess has a happening: 1. VDC Slip light flashes (and still does). 2. Car passes inspection except we had to buy a new fuel filter cap. 4. Engine light came on, then went off. 5. Now the oil light is on. Help.....some more??? thanks"
SOURCE: 2005 Pathfinder - all warning lights on
was toll before disconnect the battery for five seconds and it will clear all the lights codes
SOURCE: Loss of Power, VDC light and Slip light comes on
Have ther codes checked that are making the engine light come on first.
Btw, Iām available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: service engine soon, TCS off, SLIP
The oil change wouldn't cause this problem. Just in-case, check the engine oil level.
There are many emission sensors in the car that will make the engine light come ON. Best way to find out what's going on is to have an auto-parts store hook up a engine code reader and tell you what the code means. Most auto-part store will do this for free.
Testimonial: "very helpful. i have the mechanic checked the car , the sensor says it has a malfunction in P0340"
