Question about Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
Could it be a cracked fuel line?
Check the boot between the carb and the cylinder, it could be an air leak. also check the compression. If the piston rings are damaged then it wont have the compression to pull the fuel through. Could also be a damaged fuel line, or plugged filter.
Posted on Mar 14, 2016
SOURCE: i have a stihl ts350 cut off saw and if i put fuel
Posted on Oct 11, 2013
SOURCE: ts400 runs a while the
Does it run normally until it has warmed up? Check for a spark immediately after it cuts out. This fault can be
caused when the coil has deteriorated and heat from the engine causes
the coil to fail.
With the TS400, the other major common failure is the main bearings leading to crankcase seal failure which will cause the machine to run lean and cut out. This can easily be check for by taking the pull cord and side covers off and checking for play by trying to move the flywheel/clutch up and down. If there is any up and down movement relative to the casing the bearings have gone.
Posted on Apr 23, 2011
Jul 26, 2018 | Tank Motorcycles
Jul 05, 2018 | Motorcycles
May 10, 2016 | Motorcycles
Jun 18, 2011 | 2010 Yamaha C3
