Cell Phones Logo
Unlock torque phone
Unlock
Phone locked
what kind of lock did you mentioned here?If it is Network lock, then you can unlock your phone using unlock code from the site TheUnlockSpot.com here you need to specify your phone model,country,Network name to which it is locked,IMEI number of your phone.
1990 k1500 I from 4wd to 2wd the front axle stay's locked in. I have to take the actuator out wiggle the "pin" inside the differential to unlock it.
the pin may be locked in because of torque wind up from driving on hard surface in 4wd . Check power/ vacuum to actuator as well. Run on grass / mud/gravel/ ice surface as you try to unlock 4wd to allow the torque wind up to disappear.
Unlock torque phone
consult a technician
Jul 17, 2013 • Cell Phones
How do I unlock a torque converter on a 99 jeep Cherokee
cant unlock torque converter when internal malfunction occurs torque converter has to be replaced. sound like you have faulty TRANSMISSION TCC SOLENOID SWITCH. if torque converter stalling out the engine.
98 jeep codes p0743,p0740
Go here - www.jeepforum.com/forum/f11/tech-faq-links-tsbs-89273/ - and find the AW-4 Service and Diagnostic Manual. Looks like you need to test some solenoids.
P0740 (M)Torq Con Clutch, No RPM Drop at Lockup. Relationship between engineicon1.png and vehicleicon1.png speeds indicated failure of torqueicon1.png convertor clutch lock-up system (TCC/PTU solenoid)
P0743 (M)Torque Converter Clutch Solenoid/ Trans Relay Circuits. An open or shorted condition detected in the torque convertor clutch (part throttle unlock) solenoid control circuit. Shift solenoid C electrical fault - Asin transmissionicon1.png
P0743 (M)Torque Converter Clutch Solenoid/ Trans Relay Circuits. An open or shorted condition detected in the torque convertor part throttle unlock solenoid control circuit (3 or 4-speedicon1.png autoicon1.png. trans. only).__________________
Rather than banning scary looking black semi-automatic sporting firearms, why don't we
identify and treat the nut jobs pulling the triggers, and put the criminals in jail ?
1helpful
2answers
Torque d9 pasword unlock
Hello:
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 22, 2012 • Cell Phones
6helpful
4answers
How to reset password in torque i77 click
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Nov 12, 2012 • Cell Phones
My nokia n95 (unlocked) has no backgroung light what could be the problem and solution
I had the exact same problem. You will simply need to replace the screen by removing the four torque screws on the back of the sliding screen, pull the face cover off and unclip the ribbon to insert the new screen.
http://www.formymobile.co.uk/n958gbdisassembly.php
1helpful
1994 mazda cronos 2.00 v6 auto car idles ok drives ok but when i come to a stop it stalls in gear been atuo
This sounds like a problem with the torque converter lockup system. Usually the torque converter lockup solenoid is at fault in your condition. This solenoid usually locks up the torque convertor (which acts like a clutch in an automatic transmission) when you are driving at a certain speed, and unlocks it when you press the brake, and/or come to a stop. When a torque converter stays locked up, and you stop the vehicle, it acts like a vehicle with a manual transmission, if you bring the vehicle to a complete stop without applying the clutch pedal, the brakes stall the engine. Basically, if the torque converter can't unlock, even when you come to a stop, the engine is still locked to the transmission, and even when you apply the brakes, the torque converter doesn't slip and freewheel like it should, but instead stalls the engine.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
