SOURCE: BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
SOURCE: Need main board for BenQ Projector Model:
www.avsolutionsny.com
contact the service/repair department. they can get it in for about $280+tx.
SOURCE: rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
SOURCE: i have benq w100 projector
Possible that the main power supply has failed. So please check for tips on SMPS http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
SOURCE: How do you open a BENQ MP610 projector to replace the light? What tool do you use? Thanks Marty
I just replaced my lamp for the same beamer. Took me a while to figure out how, but if you know how, it is easy. Turn the beamer on its back. In the middle, you will see a black rubber (small), it covers a hole and a screw is in the whole. Pull the small bblack rubber out. Unscrew the screw. A small cover will come loose. And there is the lamp, You have to pull out the power cable, and than only one little screw that mounts the lamp to the inside of the beamer.
It's easy!
Hope you will succeed,
Ojnoka
