Ricoh Aficio 1515 Black and White Copier Logo
A
Anonymous Posted on Dec 10, 2013
Ghost image double image of any object when printing
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Hp 5550 patchy print
Most of the cases fuser assembly or supplies are causes of ghost image. If image is not properly transferring on media causes transfer roller or ETB.
Do this small exercise: Give print command, wait till paper grabs, once paper entered in cartridge area, power it off, open top & front cover, remove paper and see the print quality.Observed any ghost image what you observed? No ghost image? then problem with fuser assembly..
1.Remove fuser assembly, check any toner particles deposited on surface of fuser transfer roller or heater roller.. if found clean carefully with good cotton cloth while fuser having certain temperature,pl avoid metal & sharp objects to clean..
2. Clean paper path roller(You can observe the rollers to push the paper to reach the destination)
I hope this exercise will resolves the issue..
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
My zenith sentry tv has a double image on the words that come on screen. The people are clear but all wording has double images
Hello
Double images are technically called Ghosts, occures due to the setting and direction on the antena. You have to reorient your antena, in such a way that Ghosts disappeares from your screen. The reson for this fault is not with the TV, as it gets a direct transmission signal, and a reflected signal of the same, reflected from near or far objects, like tall buldings, hills and so on. The signals, the orginal and the reflected, will be processed by the TVs internal ciiruit, and the first will appear as strong picture, followed by the second, a weak picture, will be seemed as an image of the first one, just on the right side [view point] of your TV.
You just adjust the position and height of your antena, looking the picture, where there is minimum Ghost level is. No other repair should be done to your TV, as it is perfect, and you just give it only direct signal path. OK.
1helpful
Prints double image -- everything printed has a double image. Looks like a ghosted image and is offset to the actaul page.
http://www.fixyourownprinter.com/forums/laser/42756
Hi this link above directly addresses your issue with a view to a fix.
Below is how to troubleshoot your issue, it seems it can be a few things.
Below is your service and repair manual, that will have what to do. www.partshere.com/.../CLJ1600%20removal_replacement.pdf - United States http://www.streetdirectory.com/travel_guide/118490/printers/solving_image_problems_on_hp_laser_printers.html
1helpful
2answers
My printer is printing double images and leaving dark ink marks on the paper
double printing or ghost images are usually cause by a fuser that is operating below normal temperature. the temperature is regulated by the thermistor replace it or replace the fuser
1helpful
Kids removed a jam, now all prints/copies are ghosted/smear
Sounds like they touched the photosensitive drum. It needs to be cleaned with a cotton cloth. The drum is a lime-color cylinder and it is very fragile. Avoid touching with any object other than the cloth it or scratching it.
Good luck.
Double ptinting
try to clean the upper roller on heating section the final stage of the machines if the image is seen to be of the first objected copy this solution is only if you observed that the image of the previus object (source paper) is printed on the next copy or it repeats printing the lines.
and if it so replace or fix the new oil roler in heater unit.good luck vote me pls
Toshiba TN50V71
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
