this problem happened when i put new toner first try to make recovery to toner andpress2207 and show if it's works ok if there is till appear check that housing with green knob send toner to devolper tank or not some times backwards gears on machine fret thus devolper tank may effected if it been almost empty and laser revealed some times blurred image faint imagein ricoh 2035
llajajlajjajlook my friend td sensor is located in under tank devolper yo will see it but yo this disput belong to acount of devolper mesure it and check bias and high voltage board
hi ther are so many coz for that but u just start with step 1. try to set lavel of your machine. 2. clean the scanner mirors. 3. clean the crona wires both sepration and charge. if it solve your problem ok if not just cheq the devolper unit may be low devolper jut add new devolper and re calebrate .
thanks
its very simple just buy devolper and chip for devolper counter ( just empty the devolper from devolper unit and put new devolper in it and replace the counter chip at the left side of devolper unit )
thanks
your printout is only 1/2 the page than your image may not be developed or transfered. you will need to remove the deveolper unit and look at the front of it. does the devolper go all the way across the front of it?
