Casio EXILIM EX-Z1000 Digital Camera Logo
Question about Casio EXILIM EX-Z1000 Digital Camera
Camera displays "memory full" even when i insert a memory card...pls help...
Eventhough i insert a memory card, the camera displays "memory full"...cant take any pics..please help...can i get the contact number of service centre in kerala...
Posted by Dr Anuram on
5 Related Answers
Misty Hoffman
  • 374 Answers
SOURCE: does not read memory card
Casio only tested 3 cards with the camera. Sandisc, Toshiba, Panasonic. First: Format the internal memory of camera and then reset camera. In rec mode press menu go to setup tab go up to format press right arrow highlight format press set. Follow same steps for resetting. Then insert mem card and format mem card. If that still doesn't work I would say there is something wrong with the camera itself and would need to be sent in.
Posted on Jul 10, 2007
Anonymous
  • 2985 Answers
SOURCE: Memory Full
What size is the memory card. What picture size has the camera been set to? Check out your Manual for the images sizes viz a vis memory card capacity - and come back
Posted on Jul 13, 2007
Monique Nelson
SOURCE: Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Posted on Jul 11, 2008
Anonymous
  • 61 Answers
SOURCE: my EX-Z60 reads MEMORY FULL i've only taken 3 pics
I would think that you are using the built-in camera memory, by default it will allow 3 pics.
You need to go to the menu, choose setup and on the 3rd page is Format. Format your memory card
Posted on Oct 24, 2008
Anonymous
  • 53 Answers
SOURCE: SD card
It seems that you are using an SDHC (Secure Digital High Capacity) card. It's incompatible with certain older models of cameras. I think the most you can put in your camera is 2GB. I've done some research and it doesn't say anything about your camera being SDHC compatible. Return the card, get a 2GB.
Posted on Jan 14, 2009
Nikon D50 powers up but none of the functions work. Battery indicator flashes but battery is fully charged. No memory card also flashes though memory card is inserted correctly.
Hi Have you tried resetting the camera back to factory settings? This should clear up any problems...if it doesn't it may at least let you know what the problem is? Also...do not use an SD card no bigger than 2 gigs, What is thee display showing? Make sure the date and time are correct! Get back to me if you need any more help...Thanks...John,
My camera display always appear no memory card
you turned ON the camera without a menory card installed, the Syscom do not recognize any Memory.
God bless you
Camera keeps saying memory full but have inserted new sdhc card
The S1030 works with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
"Memory full" displays on screen.
You still need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format" and follow the on screen instructions to erase the internal memory. Then, insert your card and it should work properly.
My Canon SLR screen display's "No card" eventhough
Your card needs to be formatted to the camera. Once the memory card is opened on a computer to look at or download the pictures the card needs to be formatted to the camera it is going to be used in so the camera and card and properly communicate between each other.
My Canon SLR screen display's "No card" eventhough the card is properly inserted. (but the card is readable in my PC). How to fix this?
Make a back up data and re-format your memory card. If you have format the card in FAT32 and still don't work, then try to format again in FAT mode.
Hope this help.
(^_^)
Jan 08, 2011 • Cameras
3helpful
2answers
I put my memory card in my computer to upload photos; and it says there are none, but, the camera is saying its full
Does the camera say it's full even with the card out of the camera? If so, the camera is telling you the internal memory is full, not your memory card. The camera will not write to the card until you format the internal memory while the card is out of the camera.
I am apparently having trouble with the card reader, because every time i turn on the camera, it tells me that the internal memory is full, eventhough i have a memory card inserted. what can i do to solve...
To get the card to work, you must first get rid of the pics in the internal memory. With no card in the camera, go into the menu and find "format"...follow the on screen instructions. Then, your card should work.
We put a new 4gb flash card in and on the display it says no memory card,we then put the old memory card in and that says memory full but says theres no photos on the memory??pls help
Your camera probbaly does not use SDHC... just SD...
Find an SD memory card, it will work. The 4GB card says "SDHC", not "SD".
Please post the brand and model or whatever you can ... which camera?
Sep 19, 2009 • Cameras
Top Casio Cameras Experts
David Shaub
Steve
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
