Question about Roland 30"" CAMM-1 PRO CUTTER-SIGN MAKER GX-300
I get this msg when attempting to cut Error 1 Command not recognized
Cutter was working fine. After finishing my job Everything was shut down. When I switched everything back on I get an error message er1: Command not recognized. I'm working with a Dell Latitude with Windows XP.
My Macbook pro turns on but then gets stuck at the Apple logo and shuts down
Probably a bad install.
Start Mac using Command + R , install OS X on the same Hard Drive. It should fix it.
Regards
Roland Camm-1 Pro is giving Motor Error 2 in the middle of cutting. What does this error mean and how do i remedy it? All the wires are connected securely between cutter and computer.
ERROR 2:
Appears if the number of parameters differs from the permissible number.
You can download the EasyCut Pro software from https://www.easycutpro.com/ and give it a try.
This vinyl cutting software works great with Roland GX-300 CAMM-1 Pro Vinyl Cutter.
2answers
Is it worth me buying a pipe cutter or is it not something i'll ever get round to using?
If you plan to do any kind of plumbing work in your house i would strongly recommend that you invest in a pipe cutter. They give a much neater and easier finish than a saw but if you don't do much DIY and are more likely to call in a plumber than to do it yourself, don't bother spending the money.
When I calibrate the Kroy K4350, it cuts off all of the material (about 1 foot) after it finishes calibration. This will get costly as we use the printer for heat shrink tubing and change sizes of tubing...
It appears that your printer has the cut bit set to cut, from a prior print job. Suggest that you do a short print job with the cutter set to NOT cut. That should change the instruction in the machine until it has been changed to cut again. By the way, the factory advises us that the K4350 should typically NOT be using the cutter to cut heat shrink. So you may want to change the setting to NOT cut for the long haul. If this does not solve your problem, you might give us a call. We're Hanover Technical Sales, Inc. We're a premier Kroy Dealer. Call (757) 357-2677 and ask for Don.
Dell Inspiron 6400. Error 0F00:0244. On startup I get "disk read error, press ctrl+alt+del to restart. What do? I had a problem with the Ac adapter, it kept failing and powering the laptop down...
Your hard drive might be on the way out
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
I have a Royal 150mx crosscut shredder. It started making a loud noise as if one part was hitting another. It kept working for a while (I shut it down twice to let it cool down when I got the overheat...
Most likely gears inside have been damaged...open up the cutting head... see what is broken ,then contact ROYAL at 1-800-524-0799 for parts assistance.
Problem in logging in yahoo messenger
[Solution # 1]
(1) Check your firewall to be sure that this port is not blocked.
(2) Ensure that another program is not using the same port number.
Type netstat in command prompt to see all active ports.
[Solution # 2]
Goto Connection Prefrences and use a http proxy. It helped!!!
[Solution # 3]
It might do this because it cant recognize the internet. Mine does this from time to time too, but I'm not sure if I get that particular error.
Try a couple things.
1. Totally close down Yahoo! and open it back up. See if that helps.
2. If you have a Wireless connection, shut your computer down and basically reboot the connection. Unplug your modem, then your router. Wait 15-30 seconds, then plug in your modem. Wait for the lights to all become solid, plug the router back in, then turn your computer on.
Sometimes a router will stop recognizing your computer. I've had it happen to me, and the odd part of it was I could still browse the net, but not use my IMs.
3. If nothing else works, uninstall and reinstall Yahoo! IM. It may just be a glitch.
[Solution # 4]
Take a look to this address : http://epayvn.info/2009/01/yahoo-messenger-error-81003004.html
Good luck
Datamax I-4208 Cutter Fault
if the cutter cycles on start up up?
if not, check connector(RJ45) underneath platen assy.
I connected the I class should immediately recognize the cutter.
If it does not cut ever, check you format to see if the cutter is turned on in the driver.
I have seen some failures from wear on the bell crank that cycles the cutter.
2answers
HP Photosmart C4280 All-In-One Will Not Scan
hi
i had the exact same problem and i installed and un-installed
over and over again
and then it hit me !!!
why bother ??? , just download a 3rd party scanning software like "VueScan" or any other you find on google and it does the job !!
it's light, recognize the scanner (C4280) automatically and scan !!
cheers
Roland 30"" CAMM-1 PRO CUTTER-SIGN MAKER GX-300 Logo
Top Roland Computers & Internet Experts
Harrie
ADMIN Canada
ADMIN Canada
Gil Shultz
Are you a Roland Computer and Internet Expert? Answer questions, earn points and help others
