Question about Apple iPod shuffle MP3 Player
Charging ipod i have the 1st generation ipod shuffle 512 that looks like a little remote. i have had it for about 1yr now and it won't charge anymore. What can i do?
  • 515 Answers
If your iPod fails to hold a charge and it's more than a year old, you may need a new battery.
- TWEAK A/V LAB
Posted on Nov 10, 2007
6ya staff
SOURCE:
How do I charge my apple ipod?
  1. There is a cover below your iPod then once you pull that it will show like a usb connector.
  2. Then you can connect it to your computer to charge it.
Please check the video link provided below.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jul 23, 2014 | Apple iPod shuffle 1st Generation (1 GB)...
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
Updated my ipod software and now it wont play on my home theatre system
This is always tricky with 1st generation iPod touches. After a while they can't handle the new software anymore and some functions won't work anymore. Maybe try to downgrade the software. Otherwise you should probably get a new iPod.
Aug 21, 2012 | Samsung Home Theater: HT-C5500 MULTI...
How to use an ipod shuffle charge
Use iPod Reset Utility to restore the following iPod models back to their factory settings when iTunes is unable to do so. The process completely erases all music and data and reinstalls the iPod software version listed below:
  • iPod shuffle (1st generation) - iPod Software version 1.1.5
  • iPod shuffle (2nd generation) - iPod Software version 1.0.4
download here
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
then install..
follow these instructions..
Using iPod Reset Utility
  1. Quit all running applications on your computer.
  2. Open iPod Reset Utility.
  3. Connect iPod to a USB port on your computer. Do not connect iPod to a USB port on your keyboard, or other non-powered USB hub.
  4. Click the Reset button.
  5. If prompted, enter an administrator name and password. Notice: Do not disconnect iPod during the reset process.
  6. When complete, quit iPod Reset Utility and open iTunes to load music onto iPod.
Jun 05, 2010 | Apple iPod shuffle MP3 Player
What should I do during charging my ipod shuffle 3rd generation?..it should be swithc off?or turn on?. tnx
it really doesn't matter as long as you can see it in you itunes library then u know it's charging just keep one thing in mind read the manual to learn that ipod shuffle's and all ipod's have limited charging cycles meaning that someday ur ipod will die good luck
May 12, 2010 | Apple iPod shuffle 3rd Generation MP3...
How do i charge my ipod shuffle 3rd generation when red light shows
You can charge the iPod by connecting it to the Computer using the supplied USB cable.
Good Luck!!!!!!!!!!!!!
Oct 19, 2009 | Apple 3rd Generation 1GB iPod Shuffle Pink...
Ipod did not connect to pc
hi,
First Turn your PC on. The PC needs to be on to transfer music and charge the iPod shuffle. Then Place the iPod shuffle in the iPod dock connector if you have the newer version. If you're using the original version, then plug it directly into a high-power USB port on your PC. Check the monitor to ensure iTunes has loaded. This means a connection was established.
Apr 25, 2009 | Apple Audio Players & Recorders
Orange light comes on ipod shuffle but no charge...
For first generation ipod shuffles : See this document :
http://support.apple.com/kb/HT1814
For the Second Generation of the Shuffle see this :
http://support.apple.com/kb/HT1407?viewlocale=en_US
If you cannot find what you are looking for in these articles, it is very likely your IPOD Shuffle will need service.
Aug 22, 2008 | Apple iPod shuffle Second Gen. Silver (1...
My iPod shuffle will not charge
If iPod shuffle won’t turn on or respond
â If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
battery may need to be recharged.
â Turn iPod shuffle off, wait five seconds, and then turn it on again.
â You may need to restore iPod shuffle software. See “Updating and Restoring
iPod shuffle Software” on page 26.
Jun 25, 2008 | Apple iPod shuffle MP3 Player
My Ipod shuffle does not work, when I switch on the ipod, I see orange light on and off..it does not show green. I charged the battery for more than 4 hours. Can anyone help ne why is this happening and...
I am not sure about the 1st generation but the 2nd generation definitely charges via the USB connection. If you don't hear the music its because there are no songs on your device. When you initially add songs, they go to the Library in iTunes, not the Shuffle. Just drag and drop your songs from the "Library" to your "Device" in iTunes and then you'll notice them get sync'd with the Shuffle.
Jan 14, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod shuffle MP3 Player Logo
120 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
