Question about Dancing
Rainbow glitter tulle tutu
Is there a method of keeping the glitter ON the tulle?? I am making tutu's and going crazy with the glitter all over everywhere
DESMOND TUTU ADDRESS
He doesn't have a public residential address. You can try to contact him at
Suite 111, 1st Floor Clock Tower Building, Waterfront, 8001
Cape Town, South Africa, or
PO Box 50708
Waterfront
8001 or
[email protected]
Oct 21, 2016 | Office Equipment & Supplies
How do I used glitter glue on my scrapbook?
Glitter colors are small bottles of color that have glitter inside. You can use them for decorating pages, putting borders around photographs or even for writing details on the page. Just make sure that the glitter is fully dry before you turn the page.
Feb 12, 2013 | Crafts & Hobbies
How could i put a glitters with my wall at my facebook
  • SPRAY CLEAR GLITTER ON DRY WALLS -- Go to your local craft store and pick up a couple cans of spray glitter. You want a clear base so you can keep your current wall color. Look for a spray that says something like clear glitter finish or clear glitter sealer. Then just spray your walls with the clear glitter spray.
  • PAINT YOUR WALLS WITH GLITTER SPRAY PAINT -- If you want to change the color of your walls you can spray paint them with colored glitter spray paint so you get the painting and glitter done in one easy step. However, spray paint can be expensive and you may find it is difficult to get a nice even coat of paint. So this method would be good for a small room or an accent wall.
  • PAINT YOUR WALLS THEN ADD GLITTER -- This is the cheapest way to get the glittery look you want. Buy your wall paint in the color of your choice. Then buy tubes of glitter in the craft section. As you paint your walls, do one small section at a time. Then pour out a bit of glitter on a paper plate and gently blow on the glitter so it blows onto the freshly painted wall. The glitter will stick to the wet paint. Then move on to the next section and do the same thing! If you are applying two coats of paint to your walls add the glitter to the second coat.
  • Feb 27, 2011 | Graphics RSA SID700-6-60-48-5...
    In the middle of sewing some tulle my machine stoped threading the stitches , i had a look and the needle was covered in something rather sticky! has this happened to any1 else!~?what could be causing the...
    Yes, if there is an iron-on adhesive being stitched over.
    A bead of Sewer's aid along the seam line in advance of stitching will keep the needle clean - but, with tulle, it may not adhere.
    Try it on the top thread by running a bead of SA down the side of the spool to lightly coat the thread.
    Mar 19, 2010 | Brother LS-1217 Mechanical Sewing Machine
    How to maintain up keep on my rainbow vacuum
    Be sure and never store on water basin, keep separator and seal on bottom of rainbow clean. Keep your beater bar clean. You should be good for many many years.
    Jul 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
    TV Colors gone like a rainbow
    It's dignostic coil problem replace it
    or moving maganent on screen when colors have gone
    Mar 15, 2009 | Sanyo Televison & Video
    Ghjukyk
    Thanks for TUTU
    but this is not a proper place for TUTU
    Nov 27, 2008 | LaCie Electron 22" CRT Monitor
    Dancing Logo
    939 people viewed this question
    Top Dancing Experts
    magna buff
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Dancing Expert? Answer questions, earn points and help others
