Based on the symptoms you described for your Hisense model 50h5c TV, it seems that there may be a hardware issue affecting the display. Without being able to diagnose the TV in person, it is challenging to pinpoint the exact parts that may need replacement. However, there are a few components that commonly contribute to display issues:
T-Con Board: The T-Con (Timing Control) board controls the timing and signals sent to the display panel. If there are issues with half of the screen or black screen with half lines, a malfunctioning T-Con board could be a potential culprit.
Display Panel: The display panel itself could be defective, causing the black screen or half-line issue. Unfortunately, replacing the display panel can be costly and often not cost-effective compared to purchasing a new TV.
Main Board: The main board handles various functions of the TV, including signal processing and overall control. In some cases, issues with the main board can cause display problems.
1. Bad VGA on the motherboard. The VGA is responsible for display. If it's bad your screen won't display anything. 2. Defective RAM 3. Bad screen or Module 4. Faulty Motherboard. 5. The flex connecting or linking the screen to the motherboard may have lost contact.
These are the possible causes of the problem you are experiencing with your system. I hope helps to detect the main cause of the problem
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
its asking you to adjust power on the main power box it sould be under power saver adjust level it to low it should be in your menue and then your main power setings.
Your site is extremely misleading and fraudulent. I was under the impression that I would at least get a hint at what might be a problem instead of you folks making me wait to get a money for something answer that you could have displayed on your main page. Places like yours have no place on the internet and I'm going to find out what I can do to report you.
Yeah same with mine... the front screen went black.... it started to get lines up and down... then all of a sudden just the front screen turned off! :-(
