Casio FX-115ES Scientific Calculator Logo
A
Anonymous Posted on Dec 09, 2013
Divide ln6/ln8 - Casio FX-115ES Scientific Calculator
2answers
5/6÷11/12=
5/6 divided by 11/12 is the same as 5/6 times 12/11 which is
10/11. 10 divided by 11 is___________.
How to divide 1 2/3 by 3
First make 1 2/3 into a mixed fraction and then divide it by 3.
To make 1 2/3 into a mixed fraction, multiply the whole number, in this case, 1, by the denominator (the bottom number) and then add the numerator (the top number). Thus, we get (1*3+2)/3 or 5/3. Now we have to take 5/3 and divide it by 3. I was taught that in this case, dividing by 3 is the same as multiplying by 1/3. 5/3 x 1/3 = 5/9.
If you have access to a calculator you can always check this. On the calculator, do 2 divided by 3 and add 1. Now take that answer and divide by 3. Write down this answer. Now take 5 and divide by 9. Write down this answer. They should be the same.
Good luck.
Paul
I HAVE TO FIGURE OUT IF 52,63, 75,31,77,59,87 ARE PRIME NUMBERS OR COMPOSITE NUMBERS
Hi
Here we go
52 - can be divided by 2 - therefore NOT Prime
63 - can be divided by 3 - therefore NOT Prime
75 - can be divided by 5 - therefore NOT Prime
31 - cannot be divided by whole numbers - therefore Prime
77 - can be divided by 7 - therefore NOT Prime
59 - cannot be divided by whole numbers - therefore Prime
87 - cannot be divided by whole numbers - therefore Prime
Hope this is helpful, if so would you please register that with Fixya
Cheers
How cani i solve "x divided by 9 and x divided by 9 equals 4
x divided by 9 and 9 divided by 9 equals 4, so x divided by 9 equals half of 4 or 2. 2 times 9 equals 18, so x equals 18.
To check, 18 divided by 9 equals 2. 2 and 2 equals 4.
2answers
How to divide fractions using calculators?
To divide fractions proceed as you usually do with any number. Just make sure to enclose each fraction in parentheses. You may want to remember a simple rule: To divide a fraction by another, multiply the first one by the reciprocal of the other:
(a/b)/(c/d)=(ad/bc)
1helpful
How do i factor numbers on a ti-30xs calculator
This calculator does not have a key that you can use to find the prime factor of an integer.
You can however use the calculator to find the factors
1. If number is even divide it by 2
Keep dividing by 2, while keeping track of how many times you divided by 2.
If you divided 5 times by 2 before getting an odd number, then your first factor is 2^5
2. Now try dividing by 3, keep track of the number of times you divided by 3 before you could not divide by 3 any more. If you divided 0 times by 3, your second factor is 3^0, or 1 and 3 is not a factor.
If you divided 4 times by 3, your second factor is 3^4
3. Divide by 5, until you can't any more. Keep track of the number of times you divided by 5.
4. Divide by all other prime numbers 7, 11, 13, 17, 19, 23, 29, 31, 37, 41, etc. For each prime number, keep track of how many times you divided by it, until you could not any more.
Example: 23100
Division by 2
23100/2=11550 ---------> 1 division by 2
11550/2=5775 ----------> 2 divisions by 2
Note that 5775 is not divisible by 2. No more divisions by 2.
First factor is 2^2
Division by 3:
5775/3=1925 ----------> 1 division by 3
1925/3=641. 66667 Not an integer. No more divisions by 3.
2nd factor is 3^1
Division by 5 (number ends in 5)
1925/5 =385 -------> 1 division by 5
385/5=77 ----------> 2 divisions by 5 and no more (quotient does not end in 0 or 5)
3rd factor is 5^2
Division by 7
77/7=11 --------> 1 division by 7, and no more
4th factor is 7^1=7
Division by 11
11/11=1
5th factor is 11^1=11
Assembling the factors 2^2, 3^1, 5^2, 7, 11
Prime factorization of 23100 is
23100=(2^2)(3)(5^2)(7)11
2answers
Where can I buy an oriental style wooden room divider?
Amazon have got a nice range of inexpensive oriental style room dividers - plain and decorated ones. http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Acheap%20room%20dividers%20ikea
Sep 12, 2012 • Furniture
3helpful
2answers
How to calculate logrithm of base of any number in fx-991ms
you need the change of base formula:
log base b of m is ln m / ln b
So- to find log base 2 of 8, simply find ln8/ln2
(from Wikipedia - the proof also follows if you want to go look it up)
While there are several useful identities, the most important for calculator use lets one find logarithms with bases other than those built into the calculator (usually loge and log10). To find a logarithm with base b, using any other base k:
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
